Outlook DST (Daylight Saving Time) problem
LaleX
I'm trying to create a meeting event on outlook (using an outlook.com account) through a third party application we're developing. Everything works as expected, except when the "Daylight Saving Time" is effective. In this scenario, when the meeting organizer or invitees receives the e-mail with the invitation, initially the start time and end time show up correctly... but if I send another invitation or wait for few moments, the former invitation start time jumps one hour.
Example:
If the meeting start date is 8:00AM, it becomes 9:00AM.
The meeting ics contains the following "DAYLIGHT" property:
BEGIN:DAYLIGHT
DTSTART:16011020T235959
RRULE:FREQ=YEARLY;BYDAY=3SA;BYMONTH=10
TZOFFSETFROM:-0300
TZOFFSETTO:-0200
END:DAYLIGHT
I compared the ICS files that the outlook stores: the file content before the "one hour jump", and the file content after, and some properties were changed. The following are relevant data that was changed (presumably by Exchange Server):
TZID went from "America/Sao_Paulo" to "SA Eastern Standard Time" (the former is the correct one)
TZOFFSETFROM went from "-0200" to "-3000"
TZOFFSETTO went from "-0200" to "-3000"
We also tried the same thing using a Gmail account (through the Outlook 2010 client) and it behaves correctly. Therefore, i'm suspecting of something related to Exchange Server which might be changing the event.
PS: This issue was verified on Outlook 2007 and 2010 (although I doubt it has any influence whatsoever on this issue).
I appreciate any light on this matter.
Alex
D Outlook.com premium finally dying... what do I do with my domain? Using Outlook.com accounts in Outlook 1
witzker Outlook 2019 is cutting Picture Extension *.pn_ Using Outlook 3
S Is there a free version of outlook? Using Outlook 0
peterbata Shared Tasks Outlook for Mac Using Outlook 2
L Ideas for Setup with New Office 365 Family Subscription (Outlook) Using Outlook.com accounts in Outlook 3
S Excel vba code to manage outlook web app Using Outlook 8
J outlook 2007 doesn't let me choose which .pst to search Using Outlook 1
D Connecting Gmail to Outlook 365 - My Setup not working Using Outlook 1
K Outlook tasks formatting Using Outlook 4
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
H I have no profile listed for Outlook! Using Outlook 9
D Outlook 2016 how to use gmail account as source account for outlook 365 Using Outlook 9
Horsepower Contacts added from iPhone don't show up in Outlook Using Outlook 1
A Outlook (and Office) 2019 Logging Using Outlook 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
L Outlook saved template function too limited Using Outlook 2
M Outlook on 3 Computers Shows Different Total Items on Same Account Using Outlook 3
witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
witzker Open Contact missing in Outlook 2019 Using Outlook 2
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
M outlook 365 trying to finish my sentences Using Outlook 0
D Outlook Address Book Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
K Imap PC Outlook + Android phone Using Outlook 1
C All Gmails don't show in Outlook 2019 Using Outlook 2
