Need Help with Script. Keep getting Runtime Error 438
DemetriaBeth
Outlook 2013 32 bit
I have used the script that diane had in her article "Create A Letter to A Contact Using VBA". I supplied the fields that I needed, but I must be doing something wrong. I got the Compile error first, so in References I Click word object and now I am getting this runtime 438 error. Would someone mind taking a look at the script and tell me where I'm going wrong? Thanks!
Public Sub SendAddressToWord()
'Dim oContact
If TypeName(ActiveExplorer.Selection.Item(1)) = "ContactItem" Then
Set oContact = ActiveExplorer.Selection.Item(1)
' Declare the variable.
Dim oWord As Word.Application
' Set the variable (runs new instance of Word).
Set oWord = CreateObject("Word.Application")
oWord.Documents.Add Template:="C:\Users\Beth\AppData\Roaming\Microsoft\Templates\Preparer Checklist"
With oWord
' Find the bookmark, insert an Outlook field
.Selection.GoTo What:=wdGoToBookmark, Name:="FullName"
.Selection.TypeText Text:=oContact.FullName
.Selection.GoTo What:=wdGoToBookmark, Name:="ClientId"
.Selection.TypeText Text:=oContact.ClientId
.Selection.GoTo What:=wdGoToBookmark, Name:="Address1"
.Selection.TypeText Text:=oContact.Address1
.Selection.GoTo What:=wdGoToBookmark, Name:="City1"
.Selection.TypeText Text:=oContact.City1
.Selection.GoTo What:=wdGoToBookmark, Name:="State1"
.Selection.TypeText Text:=oContact.State1
.Selection.GoTo What:=wdGoToBookmark, Name:="ZipCode"
.Selection.TypeText Text:=oContact.ZipCode
.Selection.GoTo What:=wdGoToBookmark, Name:="Email2"
.Selection.TypeText Text:=oContact.Email2
.Selection.GoTo What:=wdGoToBookmark, Name:="PrimaryPhone"
.Selection.TypeText Text:=oContact.PrimaryPhone
' Show the Word document
.Visible = True
' Clear the variable from memory.
Set oWord = Nothing
MsgBox "Sorry, you need to select a contact"
does it highlight any specific line?
Is oContact.ClientId a custom field? You might need to do something like oContact.UserProperties("ClientId").
I have to go to the grocery store and don't have time to test it right now, I'm not totally sure that is correct format, but it's close.
DemetriaBeth
Outlook 2013 32 bit
Thanks for the reply Diane. Yes! It is a custom field and that is the one that was highlighted! I will try this and let you know how it turns out.
DemetriaBeth
Outlook 2013 32 bit
Hi Diane....
I redid the script and now I'm getting different errors. This is what I have:
'Dim oContact
   oWord.Documents.Add Template:="C:\"Public Sub SendAddressToWord()'Dim oContact
The colored words it says syntax error.
   oWord.Documents.Add Template:="C:\Users\Beth\Documents\PrepareChecklist"
  With oWord
    .Selection.TypeText Text:=oContact.oContact.UserProperties("ClientId")
    .Selection.TypeText Text:=oContact.UserProperties("Address1")
    .Selection.TypeText Text:=oContact.UserProperties("City1")
    .Selection.TypeText Text:=oContact.UserProperties("State1")
    .Selection.TypeText Text:=oContact.UserProperties("ZipCode")
    .Selection.TypeText Text:=oContact.UserProperties("Email2")
    .Selection.TypeText Text:=oContact.UserProperties("PrimaryPhone")
    .Visible = True
   Set oWord = Nothing
  With oWord
    .Visible = True
   Set oWord = Nothing
Are all of these custom fields? plus, you have ocontact in twice in the clientid line.
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
K Excel Import Option: Need Help Updating Existing Records BCM (Business Contact Manager) 0
K Need help concerning emails linking to BCM. BCM (Business Contact Manager) 0
J Need help with installation of BCM in Outlook2013 BCM (Business Contact Manager) 5
F Outlook 2010 - Need help with a custom field. Using Outlook 3
L Need help getting calendar/contacts/tasks/notes back! Using Outlook 3
P Need help/Gmail accounts show separately/Outlook 2013 Using Outlook 0
J Need Help Extracting Email Content into Excel Specifically the Attachment Name Using Outlook 3
A Need Help with BCM2010 Sharing on outlook 2013 Scenario! BCM (Business Contact Manager) 1
W I Need help with vb.net and outlook 2010 Using Outlook 2
A My move to MS is not going too well: Need Help !!! Using Outlook 14
M Need help with combo boxes in messages! Using Outlook 10
D Need help understanding which pst-file to use! Using Outlook 0
U Need a help please Outlook 2007 crashing Using Outlook 2
Z Need Help Outlook 2007 inbox and address book view Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Calendar Printing Assistant 1
B Need help adding an image next to the Month Name in the header. Calendar Printing Assistant 1
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
B OUTLOOK 2000, Need Help ! Outlook Wishlist 1
P To Use BCM or not...I need help BCM (Business Contact Manager) 1
T Need help making RULE to prepend email SUBJECT Using Outlook 3
V Need help on configuring Outook 2003 Rules and Alerts... Using Outlook 2
X business owner in dire need of help outlook is not syncin my contacts! Using Outlook.com accounts in Outlook 2
D Need email verification for international emails, help? BCM (Business Contact Manager) 2
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
K Need help Publishing a new Task form! Outlook VBA and Custom Forms 1
A Need help in creating a mass emailing plugin Outlook VBA and Custom Forms 1
T need help w/ sending an e-mail -- outlook 2007 addin Outlook VBA and Custom Forms 2
A Wishlist Arthur workman I need the community's assistance thank you Using Outlook 4
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
