"Specific word in body" question
jmak
Outlook.com (as MS Exchange)
Hi all,
I am trying to set a rule in outlook 2003 in order to forward an e-mail when there is a specific word in the body, for example 123.
I have created the rule using the "rules and alerts" function but when it runs it forwards not only e-mails with the word 123 but also 123456, 456123 or 412356.
I have tried using "" or spaces before and after the word without success.
Any ideas about how to form the rule so it picks up only the specific word I choose from the body and not others that may include this word as a part of them?
L Macro to Open a Specific Word Document - Outlook 2007 Using Outlook 17
T Using A Rule To Forward An Email Containing Specific Word Using Outlook 5
J Diane's Delay Delivery at Specific Times Questions Outlook VBA and Custom Forms 7
S Outlook to check for specific text Outlook VBA and Custom Forms 3
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
H Select Specific Account When Sending Email, Based on Current Folder Outlook VBA and Custom Forms 1
L Restrict accepted appts to specific calendar Using Outlook 2
P Import an .ics file to a specific calendar Using Outlook 4
A How to open a specific link automatically with outlook Outlook VBA and Custom Forms 13
O How to paste website content using a specific font and removing URLs Using Outlook 2
I Application_NewMailEx for a specific Email account Outlook VBA and Custom Forms 4
Diane Poremsky Delay Delivery of Messages Sent at Specific Times New Slipstick.com Articles 0
K Extract email to excel from a specific sender Outlook VBA and Custom Forms 3
A Block user to send emails to specific set of email ids Using Outlook 1
P Selecting specific calendar from Excel Outlook VBA and Custom Forms 5
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
M Calendar Printing Assistant Hangs only on specific Template Using Outlook 2
B Check for different domains macro to be triggered by specific domains only Outlook VBA and Custom Forms 2
N BCM suddenly crashed and not able to view specific business contact. Using Outlook 1
N Auto-forwarding an Email received from a specific Email address After slight modifications Using Outlook 4
F Outlook rule, specific words, not specific words Using Outlook 1
bifjamod Saving sent email to specific folder based on category with wildcard Outlook VBA and Custom Forms 1
nathandavies How to save emails to a specific folder on a network automatically using a macro Outlook VBA and Custom Forms 14
