BCM - personalisation problems
MAPRO
Outlook 2007
In the Business Contact Manger 2007 and 2010 we have installed, the same problem still appears.
After we create a project, join emails from Outlook
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
