Prompt on exit to empty deleted items folder "for all accounts" does not work?
AlanBru
Many of our users have Full-Access/Send-As rights on other mailboxes and have added them to their folder list (General - Advanced - Advanced - Add mailbox).
When they exit Outlook, they are prompted if they want to empty the deleted items folder "for all accounts". However, when they select Yes, it only empties the deleted items folder in their own mailbox. Right-clicking on all the other mailboxes' deleted items folder and choosing "empty" is too much trouble and they don't remember to do it every day anyway, so it becomes full.
Can anyone tell me:
1. what kind of accounts the "for all accounts" refers to? POP? IMAP?
2. is there any way to automatically empty all the deleted items folders on exit in this situation? We don't allow PST files so auto-archiving isn't an option. I want the users to manage deletions themselves so Exchange manage folders is out too. Otherwise I have to write a COM add-in.
Outlook 2010 with Exchange 2010.
- Alan.
Re: Prompt on exit to empty deleted items folder "for all accounts" does not w
For 'all accounts' is the accounts in the Account Settings list. This won't apply to managed or shared mailboxes.
Honestly, I'd set up a manage folders rule on exchange and have to clean these out as the messages age. It's less effort all the way around. You can configure it to remove aged mail, so messages would be recoverable. You can limit it to the shared mailboxes, but I would consider doing it to all mailboxes and disabling the option to delete on exit - that slows outlook down a lot on exit and can prevent it from closing properly.
AlanBru
Ok thanks for the clarification Diane. We use a third-party archiving system so managed folders aren't feasible. Deleting users' mail would not be acceptable anyway. You know how people keep messages in their Deleted Items folder ... :(
But... if they are emptying it on exit, they aren't using it as a filing cabinet.
I know how users like to file mail in the trash and I do my best to discourage it. The worst are the ones who archive their deleted mail, just in case they deleted something by mistake... I have an idea for a new reality show on the goofy cable networks - Email Horders. :)
AlanBru
We have the same GPO for everyone, they all get prompted to empty on exit. The ones who press "no" aren't the ones complaining ... :)
Ah. I still think it's worth switching to managed folders - especially since you are basically suggesting users empty the trash daily. If you use managed folders, the complainers can have 30 days to decide if they wrongly deleted something, then it can got into recovery for another 30 days. They'll learn not to use it for a filing cabinet. :) I recommend using no less than 7 days for deleted items, although if you choose to run it every weekend, then maybe 4 days, so everything deleted prior to Thursday is cleaned out - I like to give users at least a few days in case they accidently deleted something. (Which is partly why I don't like the empty on exit setting - plus it slows outlook down when exiting).
It's been awhile since I looked at the managed folder settings, but if you can apply it to groups or by attribute, you could exempt the complainers (who are often aka "the execs").
R Prompt asking the user to send email to folder as *.msg file Outlook VBA and Custom Forms 1
R Make Enter Network Password Prompt Go Away Automatically Using Outlook 0
K VBA to prompt and send a CC Outlook VBA and Custom Forms 6
K VBA - Prompt for reminder date time Outlook VBA and Custom Forms 7
P Constant Username Password Prompt Using Outlook 2
C Is there a way to prompt a user before deleting an item? BCM (Business Contact Manager) 4
S Prompt to add for text to existing subject line before sending. Using Outlook 9
S Trying to have a prompt to ask for text to be added to subject before sending. Using Outlook 3
N Prompt for password when sending an email Exchange Server Administration 1
O How to turn off the prompt to permanently delete messages upon exiting? Using Outlook 2
G Outlook keep prompt for log in credential Using Outlook 1
J Deactivate MS Outlook 2007 prompt to make it the default email client Using Outlook 1
O Outlook 2007 SP2 Prompt for Password Exchange Server Administration 3
R Does not prompt for saving or opening attachments when downloading attachment in Outlook 2007. Using Outlook 3
S Continuous password and username prompt in outlook 2007 Using Outlook 1
E Enter Network Password prompt does not accept my password Using Outlook 4
I Prompt before sending contacts to Deleted Items folder Using Outlook 7
B Password prompt for the pst files Using Outlook 9
O OWA 2003 prompt to re-auntenticate when opening up office attachments Using Outlook 10
S How to add multiple exchange accounts without password / credential prompt? Using Outlook 5
M Email Prompt Outlook VBA and Custom Forms 1
T Prompt for email account Outlook VBA and Custom Forms 1
P Outlook security prompt after installing Add-in Outlook VBA and Custom Forms 3
Q Otlk 2007 does not block when in "always prompt for..." mode Outlook VBA and Custom Forms 2
Q sending mail when Otlook in 'always prompt for user name and passw Outlook VBA and Custom Forms 4
Diane Poremsky OUTLOOK.EXE continues running after you exit Outlook New Slipstick.com Articles 0
Jennifer Murphy Exit Without Sending pop-up restarts countdown Using Outlook 11
Ross Garvey Dialogue box opens as I exit Using Outlook 2
S Autocomplete entries wiped out when I exit Outlook 2010. Using Outlook 12
S Outlook 2010 will not close on exit Using Outlook 5
C Outlook.exe hang on Exit. Using Outlook 5
vodkasoda Hiding empty Folders Outlook VBA and Custom Forms 0
Daniel Schunk User-defined form arrives empty at the recipient Using Outlook 3
semnaitik Archive PST is not empty but can't see old emails Using Outlook 2
M Multiple spurious empty folders appear in archive files Using Outlook 3
S Empty an Office365 public folder containing 20.000 messages Using Outlook 2
B Choose commands from Macros is empty Outlook VBA and Custom Forms 3
I Many empty Contacts folders.. cannot get rid of them Using Outlook 4
wisedave IMAP Mail Directory Keeps Going Empty Using Outlook 5
A Mysterious random appearance of empty unsent email Using Outlook 3
M empty fields after Contact History personalisation BCM (Business Contact Manager) 0
A email folders appear empty, at first click Using Outlook 2
H Calendar Folder property is empty Using Outlook 1
