Outlook 2010 - Need help with a custom field.
Farallon5
Hello!
I use rules a lot. One of my favorite rules is to copy incoming messages to a certain folder and set a No Date follow up flag to appear to show me that that message has a rule applied to it successfully. This way I can tell at a glance which messages have already been filed and I can just delete them from the inbox after I have read them.
Unfortunately, it is cumbersome to see WHERE the message has been filed from the message list if I have a question about it or if I suspect my rule has filed it in the wrong folder.
I can get what I want by right clicking on a message and choosing "Find Related" > "Messages in this conversation" but I would like to add a custom field in a new column that shows me which folders a given flagged message can be found in. Each folder that the message has been copied to by my rule would be shown in the field, separated by a comma. Inbox could be omitted as I am already in the Inbox.
Any help or advice would be appreciated! Thanks!
You might be able to do this using bits from a macro http://www.slipstick.com/outlook/email/sort-messages-sender-domain/ - actually, I think i would copy the message using the macro too, that way you have the folder path to insert into the field. There is a run a script rule at the bottom of the article.
use this to move it, the code on the other macro to set the field.
Dim strFile As String
strFile = "Inbox\Move"
Item.Move (Session.GetDefaultFolder(olFolderInbox).Folders("Move"))
Farallon5
I could accept (barely) running a macro to see the folder(s) that my rule directed the message to, but I think running one to do the actual moving, etc would be converting an automatic rule into a manual task. Or am I misunderstanding your suggestion?
Outlook's Rules have an Action called "run a script". Instead of using the rule to move, you'll use the same rule but remove the move Action and add run a script, selecting the move script.
Outlook's Rules and Alerts: Run a Script
Maybe something like this
Public Sub MovedToScript(Item As Outlook.MailItem)
Item.Copy (Session.GetDefaultFolder(olFolderInbox).Folders(" Move"))
Set objProp = Item.UserProperties.Add("Copied To", olText, True)
objProp.Value = strFile
Item.Save
- - - Updated - - -
Item.Save
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
J Office + Outlook 2013 installed, but I need to install Outlook 2010 Using Outlook 2
W I Need help with vb.net and outlook 2010 Using Outlook 2
R Outlook 2010 Daily Calender need high detail Using Outlook 2
S Outlook 2010, need script for rules & Warnings Using Outlook 3
N Do I need outlook connector for office 2010 as with outlook 2007? Using Outlook.com accounts in Outlook 1
