Extract text in existing message body for use in newmail items
mrsadmin
Hi there,
I'm expanding on one of my projects and I'm having issues with 1 section of the code.
Scenario:
Original received mail, I forward as a new obj to my help desk, and the file updates correctly in the helpdesk system.
The problems are this: The mail I'm using has already been forwarded on to me by my distributor (they refuse to send to our support account) and so I lose the very original subject line and the original sender. Luckily the subject line has been saved as part of the text in the email as has the sender. The unlucky part is that it's between "" so my search function has issues.
Please advise.
Existing code:
Sub Fwdfsp()
   'source:    http://bit.ly/N7ENSk (spiceworks) forward email to helpdesk as new ticket
   'source:    http://bit.ly/1bJRdeQ (microsoft) (on behalf of)
Dim stsaddress As String
Dim strbody As String
Dim oldmsg As String
Dim senderaddress As String
Dim addresstype As Integer
' Set this variable as your helpdesk e-mail address
stsaddress = "my@email"
Set objitem = GetCurrentItem()
Set objMail = objitem.Forward
'Sender email address this is fine for Sup#1, but not for Sup#2
   For Each Recipient In objitem.Recipients
       senderaddress = Recipient.Address
'Get my address for reference in the new email body
myaddress = objitem.CC
'Searches for @ in the email address to determine if it is an exchange user
addresstype = InStr(senderaddress, "@")
' If the address is an Exchange DN use the Senders Name
If addresstype = 0 Then
senderaddress = objitem.Recipients
'adds the senders e-mail address as the created by object for the ticket and appends the message body
strbody = objitem.HTMLBody
objMail.To = stsaddress
objMail.Subject = objitem.Subject
objMail.HTMLBody = strbody & "<br /><br /><font color='#000080' face='Calibri' size='1'>Received by:  " & myaddress & vbNewLine & vbNewLine
objMail.SentOnBehalfOfName = senderaddress
'remove the comment from below to display the message before sending
objMail.Display
'Automatically Send the ticket
'objMail.Send
Set objitem = Nothing
Set objMail = Nothing
Sup#1: I actually want objMail.Subject = objitem.Subject to be objMail.Subject = objitem.Body search string "original subject line in body of email"
Sup#2: I need to get the email address from the text here: Email: address
I currently have 2 instances of the code, 1 for each of the Distributors as they have different details, as you can see above. The code works well, it's just trying to extract this information.
Thank you :)
mrsadmin
Thank you, I had a look at that, but I keep running in to the issue that my original Subject is in the email with "original subject" and whenever I use the "" in my queries I keep getting errors.
I also found this a few minutes ago
Dim start_str As IntegerDim end_str As Integer
Dim mymail As String
start_str = InStr(objitem.Body, " ") + 1
end_str = InStr(objitem.Body, " ") - start_str
newsubj = Mid(objitem.Body, start_str, end_str)
Again it has the issue the my subject is always encased in "" as seen in the image: Sup#1 Attachment 906 above.
Forum Admin
You could try using chr(34) for the quotes but unless 'original subject' is used throughout the message, i'd look for those works then take the text following it, ending in /n. Even if its used multiple, as long as the one you need is always the first one, it will work.
mrsadmin
Thanks Admin.
Alas the subject always changes, what we are getting is a copy of the support ticket confirmation that the customer gets from our distributor. So the 'original subject' is always variable, however the " " quote marks are always the same.
Dear Customer,
Our staff has just replied to your ticket "Variable Subject here"
Forum Admin
Oh. I misunderstood. I thought that was the lead.
Is this always the same: Our staff has just replied to your ticket ?
Then you can use it to grab the subject.
regex pattern would be something like
> Pattern = "your ticket\s*(\w*)\s*\n"
mrsadmin
I feel like i'm the trial & error Queen tonight :) It's taken hours, but I got there in the end. It is not pretty, but I did it.
If you can see a better way then please let me know (I tried Diane's string but it wouldn't move past the ").
.Pattern = "(your ticket (\s*\W*\w*\s*\w*\s*\w*\s*\w*\s*\w*\s*\w*))"
Sub Fwdfsp()
   'source:    http://bit.ly/1gfAHAj (techniclee) strip Fwd
   'source:    http://stackoverflow.com/a/20337850/2337102 (find email)
   'source:    http://bit.ly/1cpghpi    (outlook forums setting the regular expression)
   'source:    http://bit.ly/1eQsX56   (slipstick using RegEx)
   'source:    http://bit.ly/1jQrtzY       (regex cheat sheet codes)
   'source:    http://bit.ly/1cZ9AXW   (mrexcel) (remove first character in string)
Dim custmail As String
Dim origsubject As String
Dim newsubject As String
'reg search
Dim Reg1 As RegExp
Dim M1 As MatchCollection
Dim M As Match
Dim strSubject As String
Dim testSubject As String
'gets the original email & creates a new one
'-----     -----     -----     Search & apply from objitem     -----     -----     ---
'Sender E=mail Address needed for exchange option
       custmail = Recipient.Address
       'add  & ";" & strRecip  if more
addresstype = InStr(custmail, "@")
'If the address is an Exchange DN use the Senders Name
custmail = objitem.Recipients
'-----     -----     -----     Getting subject from original item using RegEx     -----     -----     ---
    ' \s* = invisible spaces
   ' \d* = match digits
   ' \w* = match alphanumeric
Set Reg1 = New RegExp
   With Reg1
   '    .Pattern = "your ticket\s*(\w*)\s*"
       .Global = False
   If Reg1.Test(objitem.Body) Then
       Set M1 = Reg1.Execute(objitem.Body)
           For Each M In M1
               'Debug.Print M.SubMatches(1)
               origsubject = M.SubMatches(1)
               'newsubject = M.SubMatches(1)
               'strSubject = Replace(strSubject, Chr(13), "")
               'testSubject = testSubject & "; " & Trim(strSubject)
           'Debug.Print i & origsubject
'remove the " at the start of the subject line from origsubject
newsubject = mid(origsubject, 2)
'-----     -----     -----     Setting Variables     -----     -----     ---
'Set variable email addresses
helpdesk = "support@mail"      'support system
admin = "admin@mail"            'future correspondence
'-----     -----     -----     Getting data from original item     -----     -----     ---
irisreceived = objitem.CC                                    'address which received original email
distemail = objitem.SenderEmailAddress                 'distributors originating email
custmail = objitem.To                                        'customers address from originating email "to"
'-----     -----     -----     Creating the new email as a modified forward item     -----     -----     ---
'gets the original body to insert in to the new email
intro = "TaDa"
'setting the email up
objMail.To = helpdesk
objMail.Subject = newsubject
objMail.HTMLBody = intro & strbody
objMail.SentOnBehalfOfName = custmail
' remove the comment from below to display the message before sending
objMail.Display
'objMail.Send
Forum Admin
Should be able to condense it down to one of these (but i didn't test it)-
> Pattern = "(your ticket\s*([\w-\s]*))\n"
> Pattern = "(your ticket\s*(.*))\s*\n"
The second one covers it if there are non-alphanumeric characters, the \w-\s get alphanumeric and white space.
mrsadmin
Woot! Got it to work :) Thank you both very much!
From this: "Re Your Product" to: Your Product
I had to remove the " " and then the ' Re ' (the Re caused a whole lot of grief, but I came up with the solution below, from alternative sources).
It's possibly not the neatest code ever written, but so far it does work. :)
Ques:
Your pattern will that work on all email addresses?
It works on a current one: names @domain. tld.country (no spaces) (false @ false. com.au)
Will it work on things like the gmail accepted addresses: name.name+random @gm .com (mrs.admin+outlookforums @gm .com)
or on sub.domains?
From my testing it will do, but I haven't tested all possible combos.
What an awesome little snippet of code! :)
'source info removed for brevity
   With Reg1
         .Pattern = "(your ticket\s*(.*))\s*\n"
         'was:  .Pattern = "(your ticket (\s*\W*\w*\s*\w*\s*\w*\s*\w*\s*\w*\s*\w*))"
       .Global = False
           For Each M In M1
   'origsubject = original found in email
   'basesubject = original less the "" (Quotes)
   'edsub = basesubject, ready to edit in the case of Fwd, Re, etc
   'newsubject = edsub (e) with all the Fwd, Re etc removed as well as any leading remaining whitespaces
   'edsub resulted in the following ' Re Your Product' ( with no ')
basesubject = mid(origsubject, 2, Len(origsubject) - 3)
edsub = basesubject
Dim e As String
e = edsub
e = Replace(e, "RE:", "")
e = Replace(e, "Re", "")
e = Replace(e, "Fw ", "")
e = Replace(e, "Fwd: ", "")
newsubject = LTrim(e)
   'I had tried using another code based on the following however it didn't account for any mid-sentence [I]Fwd/Re[/I] or when ( [I]Fwd: Re:[/I] ) etc:
   'subject has Fwd / Re in it
   'If (Left(objMail.Subject, 4) = "FW: ") Or (Left(objMail.Subject, 4) = "RE:") Then
'        objMail.Subject = mid(objMail.Subject, 5)
'        objMail.Save
'    Else
'        If Left(objMail.Subject, 5) = "Fwd: " Then
'            objMail.Subject = mid(objMail.Subject, 6)
'            objMail.Save
'    Else
'        If Left(objMail.Subject, 3) = "Re " Then
'           objMail.Subject = mid(objMail.Subject, 4)
'           objMail.Save
'        End If
'End If
'End If
you mean will this work on email addresses? .Pattern = "(your ticket\s*(.*))\s*\n"
Yes, it will work on anything - the (.*) covered everything between 'your tickets' and a line break.
mrsadmin
Hi all,
Well, the project is completed, so far :) Since learning about constants I think I want to implement a few in the code. Things like the support email, the distributor email, things like that which won't change.
Here is the "Reply to Distributor (acknowledging I received & forwarded the email)"; "Send to Support System" and "Original from Distributor" emails.
It looks messy, the code doesn't look much better.
I've got 6 versions of the code.
1 Fwd & 1 reply per Distributor account (Only 2 from 4 I deal with)
1 Fwd & 1 reply for customers who email admin instead of Support.
I have kept the versions in 1 module per pair (Fwd & Reply in 1), and I call it through another Macro (very basic "Sub name(), Call name End Sub" (a couple of "IF" statements in there), this way if the distributors ever change the way they send their emails I can just head to that module and fix the 2 that are relevant. I would like to clean it & streamline, but for now this is a huge achievement for me
SO, this is it :) Distributor #2:
Button:
Sub stsNew()Dim distemail As String
   If distemail = "info@ wer" Then
      Call stsFSS
   If distemail = "sales@ xyz" Then
      Call stsFSP
  Call stsISS
The whole code is in part 2 due to character restrictions :)
'source: http://bit.ly/1jUx4VO (mrexcel) (remove last character in string)
'source: http://bit.ly/1hdbabz (outlook forums RegEx short .pattern)
'source: http://bit.ly/1jPWSiO (mrexcel) (replace values)
I don't know how to stop having to repeat the "Function GetCurrentItem() As Object", I have to add it in every module, it won't work if I put it in my "FunctCommon" module with the others I use.
[FONT=Verdana]Function GetCurrentItem() As Object[/FONT]
[FONT=Verdana]Dim objApp As Outlook.Application[/FONT]
[FONT=Verdana]Set objApp = Application[/FONT]
[FONT=Verdana]On Error Resume Next[/FONT]
[FONT=Verdana]Select Case TypeName(objApp.ActiveWindow)[/FONT]
[FONT=Verdana]Case "Explorer"[/FONT]
[FONT=Verdana]Set GetCurrentItem = _[/FONT]
[FONT=Verdana]objApp.ActiveExplorer.Selection.item(1)[/FONT]
[FONT=Verdana]Case "Inspector"[/FONT]
[FONT=Verdana]objApp.ActiveInspector.currentItem[/FONT]
[FONT=Verdana]Case Else[/FONT]
[FONT=Verdana]End Select[/FONT]
[FONT=Verdana]End Function[/FONT]
mrsadmin
And this is the magic (messy, I know):
Part 1/2 (char limit)
Sub Fwdxyz()
Dim abcsts As String
Dim abcadmin As String
Dim abcreceived As String
'reg search
Dim Reg1 As RegExp
Dim M As Match
'-----     Search & apply from objitem     ---
'Sender email Address needed for exchange option
'-----     Getting subject from original item using RegEx     ---
   With Reg1
       .Global = False
           For Each M In M1
'newsubject = edsub (e) with all the Fwd, Re etc removed as well as any leading remaining " " whitespace
edsub = basesubject
Dim e As String
e = edsub
'-----     Getting customer name from original item using RegEx     ---
   With Reg1
         .Pattern = "(Dear\s*(.*))\s*\n"
       .Global = False
           For Each M In M1
               origname = M.SubMatches(1)
custname = mid(origname, 1, Len(origname) - 2)
'-----     Setting Variables     ---
abcsts = "support@ abc"            'support system
abcadmin = "admin@ abc"         'future correspondence
'-----     Getting data from original item     ---
abcreceived = objitem.CC                 'address which received original email
dist = "xyz"                               'Distributor short code
origemaildate = objitem.ReceivedTime
'-----     Creating the new email as a modified forward item     ---
objMail.To = abcsts
objMail.Subject = newsubject & "  [" & dist & "]"
objMail.HTMLBody = "<font color='#000080' face='Calibri' size='2'>-----     -----<br>" & _
                                           "The below ticket has been received and forwarded on to our Support Ticketing System " & _
                                          "(<a href=''www.abc .com' target='_blank'>sts</a>)." & _
                                          "<br>Sent from:               " & distemail & _
                                          "<br>Customer name:       " & custname & _
                                          "<br>Customer email:       " & custmail & _
                                          "<br>Received by:            " & abcreceived & _
                                          "<br>Forwarded to:      " & abcsts & _
                                          "<br>Forwarded by:            " & abcadmin & _
                                          "<br>Original email date:        " & origemaildate & _
                                          "<br>vvvvvvvv <br>-----     -----<br><br> " & _
                                          "Original message begins:<br>" & _
                                          "-----     -----<br><br> </font>" & strbody
objMail.Categories = "CS: D: xyz"
objMail.Display                'remove the comment to display message before sending
'objMail.Send                'Automatically Send ticket
Cool. Thanks.
GetCurrentItem should error if its in multiple modules - that has always been my experience. It's not labeled private, so it should be seen from any module.
BTW, I'm moving the forum to new software (xenforo, Saturday night if it snows***) and will lift the message size restrictions for all but new members. This forum has just one setting - and yes, i could lift it for all, but I'm too lazy to change the setting. :)
***It's snowed every weekend since Jan 1, so what are the chances? :) If it doesn't snow, we need to visit family out of state.
mrsadmin
Part 2/2 This is the reply to the distributor.
I had tried to reduce the Regex down to the CASE example as per Diane's REGEX page (here), however I couldn't figure out how to set the 2 different pieces of detail (subject & name), it would just revert to the Subject.
Sub Replytoxyz()
'Set objitem = GetCurrentItem()
Set objitem = ActiveExplorer.Selection.item(1)
If TypeName(ActiveExplorer.Selection.item(1)) = "MailItem" Then
Set oMail = ActiveExplorer.Selection.item(1)
' For a reply or reply all, replace forward  with Reply or ReplyAll
Next Recipient
   With Reg1
       .Global = False
           For Each M In M1
newsubject = basesubject
   With Reg1
       .Global = False
           For Each M In M1
foremaildate = Format(Now)
'set other items
sig = ReadSignature("abc - all.htm")
objMail.To = distemail
objMail.Subject = "Re: " & objitem.Subject & "  (" & newsubject & ")" & "  [" & dist & "]"
                                           "Hi Team, <br><br>" & _
                                           "(<a href='www.abc .com' target='_blank'>sts</a>).<br>" & _
                                           "The customer should expect contact within the next 48-72 hours, longer if sent over a weekend or public holiday.<br>" & _
                                           "If you would like the reference number for their support ticket for your records please let me know.<br><br>" & _
                                           "<br>For Customer:      " & custmail & _
                                           "<br>Forward email date:       " & foremaildate & _
                                           "<br><br>Please do not hesitate to contact us if you have further questions.<br><br>Thank you<br><br>" & _
                                           sig & "-----     -----<br></font>" & strbody
objMail.SentOnBehalfOfName = abcadmin
And I'm done ... sorry for the 3 posts but the code is huge and had to be split up :)
I really should learn more so I can reduce it more ;D
mrsadmin
Cool. Thanks.
We've had huge extremes here, up to 42oC days, as low as 13oC. Completely weird weather, and hubby's family are being flooded in the UK. Mother Nature has gone mad this year.
Considering the amount of duplicate code I have, what's another "Function", I found it odd it wouldn't pick up from my central function module, but, I don't know any better :)
I have 1 in there that is used for the Categories code that I use, and even though they are identical in code, when I delete the "CurrentItem" in my personal module I get the "Ambiguous Name" error. If I leave them both in, (common & personal) there aren't any errors.
I didn't see your reply before I posted Part 2 of the code.
I'm just thrilled that this project has worked, and it was from the help here that made it happen. I'm such a n00b :) hehe.
K extract certain text from an Outlook Email Message Outlook VBA and Custom Forms 2
D VBA Script to extract text matching specific criteria Outlook VBA and Custom Forms 1
R Saving Outlook Email As Text File Extract Outlook VBA and Custom Forms 2
N Extract Outlook emails to excel Outlook VBA and Custom Forms 2
T Extract Data From Outlook Tasks Using Outlook 0
V extract users of a particular department Outlook VBA and Custom Forms 1
S How to extract mail items from multiple folders and shared mailboxes? Outlook VBA and Custom Forms 0
R Trying to extract information between two symbols from outlook subject Using Outlook 2
K Extract email to excel from a specific sender Outlook VBA and Custom Forms 3
O VBA to extract email (fields and body) to Excel Outlook VBA and Custom Forms 14
P Recover / Extract Rules from standalone PST file creating RWZ file Using Outlook 2
B Extract Dates for Appointment Item in Body of email Outlook VBA and Custom Forms 10
D Need to extract a line from a word attachment, and add it to the subject line Outlook VBA and Custom Forms 3
E Extract excel files from outlook Outlook VBA and Custom Forms 2
M Extract attachments with a script Using Outlook 0
M HELP - Can't open outlook... How can I extract my Emails that I had in folders Using Outlook 3
H Extract emails from Outlokk 2007 email body Using Outlook 0
K Extract Global Address List Using Outlook 1
N Programming to extract automatically extract attachments Outlook VBA and Custom Forms 3
S How to extract outlook calendar data. Outlook VBA and Custom Forms 3
? outlook attachment Extract File ??? Outlook VBA and Custom Forms 1
N How to extract date and time stamp from messsages Outlook VBA and Custom Forms 6
V Extract Subject,Sent From, Message from mailbox to Excel Outlook VBA and Custom Forms 5
S Automatically extract attachments? Outlook VBA and Custom Forms 1
I How to extract email addresses from TO or CC line of a particular email Outlook VBA and Custom Forms 2
S Outlook to check for specific text Outlook VBA and Custom Forms 3
