BCM 2010 Problem with remote office (VPN) users cannot connect
ramtec
We have BCM databases in London and wish to connect a few remote offices. I am trying to get BCM working on machines in Sri Lanka.
I have run the BCM setup successfully with my user account (created on one of the machines applying the switch user trick), however no matter what I try I cannot get the two Sri Lankan accounts to see the database.
servername\mssqlserver,1433
It works for me and not for them so I know there are no port, firewall routing issues, they are both added to the database using the BCM tool.
I've been working on this for weeks so please help while I have hair left.
Many thanks in advance.
Could the firewall on their computers be blocking the ports? If it works for you it means the server's firewall is allowing it to get through, as is the firewall on your computer.
Are you using domain logons?
What language are they using, both in outlook and the OS? Is it the same as you are using?
ramtec
Many thanks for the speedy reply.
I've setup my domain account on their computers and configured outlook and BCM fine so can't see it being firewall as I would have the same problem trying to connect?
Yes domain logons
It's English on both
Well, we can rule out problems with the languages.
Oh, so you are using their computer with your domain account and its fine, it's only their account that has the problem? I'd look at the SQL server permissions. Are their accounts being Denied permissions? Have you checked the server's Event log for login errors?
- - - Updated - - -
ramtec
Thanks again, I will look at the logs. I would of thought that if added and deletedthem from the bcm tool that would be enough. Not having any problems with any London based accounts. I will also double check the languages under their profiles.
Adding them using the BCM tools should be enough since they are domain accounts, but if the accounts have explicit deny permissions to the server, it will be a problem.
ramtec
Sorry I forgot to mention. I have setup a laptop remotely (vpn) using one of the Sri Lankan domain accounts and have successfully linked into the London server.
ramtec
so, I have double checked the languages and both are the same UK English on both outlook and os. I know my account works on their machines and their account works via vpn on my test machine. but still getting the computer xxx is not available when I try to connect using their accounts, very frustrating!
It's something with the login. Their computers are logging into the domain - are they using the same login with the VPN? In a VPN situation, I'm not sure which login passes credentials.
ramtec
thanks again for the help, yes I think you are right re the login. I was going to delete/rename the account and then get the user to re-login, however it's happening on all Sri Lankan accounts but will try anyhow.
The vpn works fine for my account using their computers, the vpn accounts on the router have been setup exactly the same.
Are you all logging into the same domain or do they have a domain local to their location they use for the computer login?
If they have two different domains, make sure the one the computer logs into is given permission on the server. BCM is passed the computers username and password.
ramtec
sorry should have been more clear, just one domain, accessed through vpn when they need to connect to the server based in London. Outlook anywhere and cached account used for day to day activities apart from BCM and shared server folders when vpn would be used.
I'm pretty sure its permissions but i don't know whether its on the SQL server or elsewhere.
Forum Admin BCM Update for Outlook 2010/2013 - Nov 2014 BCM (Business Contact Manager) 14
JimR BCM 2010 or 2013 BCM (Business Contact Manager) 6
J Migration from BCM 2010 to 2013 is messing up the label fields BCM (Business Contact Manager) 4
T BCM 2010 Archiving Communication History BCM (Business Contact Manager) 2
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
R BCM is almost at capacity Outlook 2010 BCM (Business Contact Manager) 2
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
V Permissions in BCM 2010 BCM (Business Contact Manager) 3
M Is there a list of FieldNames that BCM 2010 uses? BCM (Business Contact Manager) 0
A BCM 2010 converts html e-mails to plain text BCM (Business Contact Manager) 1
A BCM 2010 account names import in reverse order BCM (Business Contact Manager) 4
B BCM 2010: Exporting Notes to .CSV with Business Contacts? BCM (Business Contact Manager) 3
J BCM 2010 - New user cannot connect to remote DB BCM (Business Contact Manager) 5
E Can we make custom form as default form in BCM 2010? BCM (Business Contact Manager) 5
N BCM 2010 for CRM tool? BCM (Business Contact Manager) 3
S BCM 2007 to 2010 migration failure issue BCM (Business Contact Manager) 1
R Sorting and crossing over project tasks in project window (BCM 2010) BCM (Business Contact Manager) 1
M BCM 2010 Cannot Connect to Remote Database BCM (Business Contact Manager) 1
M BCM 2010 Link to Record (very) slow BCM (Business Contact Manager) 2
D [SOLVED] Optimizing Outlook 2010 BCM BCM (Business Contact Manager) 2
C Outlook 2010 with BCM - Database Connection problems using Windows 7 Clients Using Outlook 1
T Custom forms BCM 2010; use of form controls Using Outlook 1
S Recovering .sbb file that should be a .bcm file for Business Contact Manager 2010 Using Outlook 3
M Where are contacts stored for BCM 2010? Using Outlook 1
I Outlook 2010 BCM Mass E-mail feature insists on converting outbound HTML emails to plain text Using Outlook 2
I Office 2010 BCM Using Outlook 1
N Receive "Requested Operation Failed" Dialog when trying to add BCM Database in Outlook 2010 Using Outlook 2
B Outlook with BCM 2010 and Windows Mobile will not sync contacts separately Using Outlook 1
P Communication History disappeared in BCM 2010 Using Outlook 22
D BCM for Office 2010 Pro Plus Using Outlook 1
R BCM 2007 to 2010 Conversion fails - Database size > 4GB Help! Using Outlook 1
G Importing BCM file into Business Contact Manager 2010 Using Outlook 3
L 2010 BCM Install Using Outlook 1
K BCM 2010 - Permissions Setting? Using Outlook 1
J outlook and BCM 2010 have Hyper links fileds Using Outlook 3
N BCM 2010 Will Not Setup Using Outlook 2
Forum Admin Download BCM 2010 BCM (Business Contact Manager) 0
T Import Outlook 2003 .bcm file into Office 2010 Bus. Cont. Mgr. Error: "Input string was not in a cor Using Outlook 6
C BCM 2007 to 2010 Migration BCM (Business Contact Manager) 1
A Using BCM 2010 mass email - how do you control which outlook email account does the sending? Using Outlook 6
