Problem With Mail Setup IN Outlook 2013
Tomohawk
I’m experiencing a problem with my mail setup on a notebookwith Outlook 2013.
I have Outlook 2010 on my desktop and when I want to travel,I simply copy my PST files to an encrypted drive on my notebook and use themwith Outlook 2013. I know it's t bet practice, but it works just fine for me.
My desktop runs Windows 7 (32-bit) and my notebook runs Windows8.1 (64-bit).
I have three mail accounts in a single profile.
When I open Outlook on my notebook, the main e-mail accountperforms perfectly well (send/receive), but the other two have a send/receive error 0x8004010F
I close Outlook and go to Mail in Control Panel.
I select the profile, click on Properties and click on EmailAccounts.
When I select one of the erroring accounts and click on “ChangeFolder – Selected account delivers new messages to the following location” andselect the appropriate Inbox, - nothing happens.
I have checked the setup of the erroring accounts and they areset up correctly and also the data files are correct.
They are all POp3 accounts? I've seen this before, where Change Folder didn't work, and the fix was to remove the accounts and re-create them. You can try using the Repair button in the Account Settings dialog - select one of the affected accounts and click Repair. Repeat for the other one.
Tomohawk
Yep! All POP3.
Started from scratch again and all is ok now.
D Problem with MS mail and outlook 2007 OS Windows 8 Using Outlook 1
E Mail problem Using Outlook 3
S Problem syncing mail from a POP3 account in Outlook 2013 to iphone 5 Using Outlook 1
B Problem with new imap mail account with delete not working as I would like Using Outlook 2
R problem with incomming e-mail I am unable to print full e-mail letter Using Outlook 1
M Problem/Glitch with unread mail and going back to inbox --- missing emails Using Outlook 1
A E-mail accounts problem !!! Using Outlook 7
E Outlook invitation request mail sending twice problem Using Outlook 1
N Automating Outlook 2007 problem with sending mail Outlook VBA and Custom Forms 1
P UserProperty of mail object problem while dealing with custom fold Outlook VBA and Custom Forms 2
e_a_g_l_e_p_i Is anyone else having problem conneccting to gmail? Using Outlook 20
