Outlook 2013 & BCM Issue
bjbizz
Outlook 2013 64 bit
Have upgraded to BCM 2013 and for the most it has all upgraded ok. The only problem that I have with it is that the email fields are all mixed up.
By default all emails have been moved into the E-mail 2 field? When I choose from the drop down list and choose E-mail 2 it then changes to E-mail 3?
Not sure what is going on. Is there a reset that I could run to get these fields back in the right order?
Forum Admin
Known issue. I have a reminder into my contact about this. I'm hoping its fixed soon. :( I don't think you can change the order.
Forum Admin
This bug is being worked on. No ETA for a patch, but it's expected to be in a future BCM update, not an Outlook update.
Forum Admin BCM Update for Outlook 2010/2013 - Nov 2014 BCM (Business Contact Manager) 14
JimR Outlook 2013 BCM not working BCM (Business Contact Manager) 3
J BCM 2013 in Outlook 2013 will not load BCM (Business Contact Manager) 5
S BCM stops Outlook 2013 BCM (Business Contact Manager) 6
K bcm not showing in outlook 2013 navigation pane BCM (Business Contact Manager) 3
G "database is not compatible with BCM for Outlook 2013" & more BCM (Business Contact Manager) 0
M Queries on Business Contact Manager (BCM) with Outlook 2013 Using Outlook 1
V BCM Use with Outlook 2013 BCM (Business Contact Manager) 42
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
M OUTLOOK 2013 CONTACT PROPERTIES Using Outlook 0
M Outlook 2013 Using Outlook 1
