BCM does not start correctly
andyga
Hello
after 2 days "working" with BCM now it does not start with Outlook 2013
I tried to reinstall but nothing changed
In Outlook Options - Addinns - goto - COM ADDIN - I clicked on BCM Manager for Outlook and Loader but there is an unknown external error
Do I have to uninstall Outlook?
I can see BCM at the left folder
but it is not at the navigation folder and not either in the FILE menu
andyga
Hello Diane
I disinstalled BCM and Office 2013
Then I restarted the PC and installed Office 2013. Then SP1
(proplussp2013-kb2817430-fullfile-x86-de-de.exe 655 MB)
after that I installed BCM
(BCM2010-BCMSetup-x86-de-DE.exe 451 MB)
but it still does not work! is there any problem with SP1, or do I have to install a compatibility pack?
you said "I hate BCM some days" - does this means that this happens often? Because here I only try BCM with Outlook 2013 for our company and then I will install it on 3 PCs
If it allways has this problems I cannot install it and I will buy ACT!16
I have not been able to get BCM to work on my desktop since I updated to updated to Windows 8.1. It works, most of the time, on my laptop and (knock on wood) and fine in a virtual machine running Windows 7. I had a lot of problems with Outlook blocking BCM because it either caused outlook to start too slowly, close too slowly, or caused Outlook to crash.
If you are using Act now and it meets your needs, I'd probably stick with it. I don't have a lot of confidence in the future of BCM - it's impossible to know if Microsoft will keep updating it for future versions of Outlook. They will be releasing an SP1 update, although I don't know when. That update will fix the problem with phone labels being wrong (along with other things).
Check the event viewer for messages relating to Outlook or BCM, they may give us some clues.
andyga
I have the following errors:
9 times Security-SPP
Outlook
Office 14
Office 15
twice Windows Error Reporting
Security-SPP has to do with some sort of licensing check. AFAIK, that is windows related, so its not affecting outlook.
what does the outlook error say? Just the first few lines should be enough information, not the entire error.
andyga
it was more simple to copy all:
Protokollname: Application
Quelle: Outlook
Datum: 08.03.2014 16:39:37
Ereignis-ID: 45
Aufgabenkategorie:Keine
Ebene: Informationen
Schlüsselwörter:Klassisch
Benutzer: Nicht zutreffend
Computer: Wohnzimmer
Beschreibung:
Outlook hat folgende Add-Ins geladen:
Name: Microsoft Exchange-Add-In
Beschreibung: Exchange-Unterstützung für Unified Messaging, E-Mail-Berechtigungsregeln und Kalenderverfügbarkeit.
ProgID: UmOutlookAddin.FormRegionAddin
GUID: {F959DBBB-3867-41F2-8E5F-3B8BEFAA81B3}
Ladeverhalten: 3
HKLM: 1
Speicherort: C:\Program Files\Microsoft Office\Office15\ADDINS\UmOutlookAddin.dll
Startzeit (Millisekunden): 31
Name: Outlook Connector für soziale Netzwerke 2013
Beschreibung: Stellt Verbindungen mit Websites mit sozialen Netzwerken her, und bietet Personen-, Aktivitäts- und Statusinformationen.
ProgID: OscAddin.Connect
GUID: {2163EB1F-3FD9-4212-A41F-81D1F933597F}
Ladeverhalten: 3
HKLM: 1
Speicherort: C:\Program Files\Microsoft Office\Office15\SOCIALCONNECTOR.DLL
Startzeit (Millisekunden): 47
Name: OneNote-Notizen zu Outlook-Elementen
Beschreibung: Fügt der Befehlsleiste die Schaltflächen 'An OneNote senden' und 'Hinweise zu diesem Element' hinzu
ProgID: OneNote.OutlookAddin
GUID: {93E5752E-B889-47C5-8545-654EE2533C64}
Ladeverhalten: 3
HKLM: 1
Speicherort: C:\Program Files\Microsoft Office\Office15\ONBttnOL.dll
Name: Microsoft SharePoint Server-Kollegenimport-Add-In
Beschreibung: Mithilfe dieses Add-Ins werden vom Microsoft SharePoint Server Kollegenvorschläge basierend auf Ihrem Outlook-Inhalt importiert
ProgID: ColleagueImport.ColleagueImportAddin
GUID: {EFEF7FDB-0CED-4FB6-B3BB-3C50D39F4120}
Ladeverhalten: 3
HKLM: 0
Speicherort: C:\Program Files\Microsoft Office\Office15\ADDINS\ColleagueImport.dll
Startzeit (Millisekunden): 0
Ereignis-XML:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Outlook" />
<EventID Qualifiers="16384">45</EventID>
<Level>4</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2014-03-08T15:39:37.000000000Z" />
<EventRecordID>175262</EventRecordID>
<Channel>Application</Channel>
<Computer>Wohnzimmer</Computer>
<Security />
</System>
<EventData>
<Data>Outlook hat folgende Add-Ins geladen:
Ladeverhalten: 3
HKLM: 1
Ladeverhalten: 3
HKLM: 1
Ladeverhalten: 3
HKLM: 1
Ladeverhalten: 3
HKLM: 0
</Data>
</EventData>
</Event>
I don't think so. Are you getting the same error message?
(Or maybe it has... :) Not that reinstalling Windows is an acceptable fix... )
J What exactly does the BCM Database tool actually do? BCM (Business Contact Manager) 3
T Office2013 and BCM on Windows 8.1 -- install of BCM does not work? BCM (Business Contact Manager) 2
E BCM Search does not show results BCM (Business Contact Manager) 1
D Why does BCM not always load when I restart Outlook? BCM (Business Contact Manager) 1
D Does BCM integrate with Navision Dynamics 5.0 or greater? BCM (Business Contact Manager) 1
J WINDOWS EASY TRANSFER does not allow for BCM BCM (Business Contact Manager) 1
D Win7 x64 - Outlook 2010Beta x64 - BCM 2010 x64 does not install BCM (Business Contact Manager) 1
S BCM does not load in Windows 7 BCM (Business Contact Manager) 1
J Where does BCM store User-Defined fields in the database? BCM (Business Contact Manager) 3
E How does BCM links items BCM (Business Contact Manager) 1
Diane Poremsky Restoring BCM Database After Upgrading Windows New Slipstick.com Articles 0
Diane Poremsky Outlook 2016: No BCM New Slipstick.com Articles 0
