Problem with Reminder appearing in Inbox
rhp52
Outlook 2007
Hi - I hope you can help me with this- somehow a reminder has appeared in my inbox that includes all of my current emails (137) in the inbox. Have no idea how this happened except to say I was designating 1 message to high importance when the next thing I know, there is this 'reminder' at the top of my inbox with all my email included in it.
Tried to find a way to remocve it to no avail. I'm afraid if I delete it I will delete the emails as well. Help! Using Outlook 2007 SP3
thanks
rhp52
Outlook 2007
thanks for responding Diane..No, this is my Inbox. I have not checked any messages. the reminder appears at the top of my inbox in gray. It reads: Reminder: NO (135 items). In addition, any new email I receive now comes under a reminder located at the bottom of my inbox. It reads Reminder: None (23 items, 22 unread). Obviously the number of items and unread is variable.
Opening the reminder window is no help as there's nothing there to remove. I'm out of ideas. I'm aware of a folder reset you can do but am afraid of losing my inbox content. Any insight into this workaround?
rhp52
Outlook 2007
Diane- Problem has been found! Under View/Arrange By/ somehow got changed to 'Custom' instead of 'by Date'. Changed it back and the 'Reminder' is gone. Whew.
thanks for responding. I thought my Inbox was corrupted.
Ah, you were grouping the inbox by the reminder field.
Sent from my iPad using Tapatalk
merisel8
Diane, I am having a vey similar problem to this but not sure how to fix it. I had to reinstall my Outlook version 2010 because of a glitch. When I installed it I went to set an appointment with a reminder, however it came back with the following “The reminder for “<subject>” will not appear because the item is in a folder that doesn’t support reminders. “ A friend suggested I right click on that pst and select "Data File Properties"...make sure check box
I don't know how to find the PST file to find the portion in the red box to check it off. None of what I tried had this box. Please advise.
My other challenge is that I am not having my calendar items update on my iPhone calendar, when it did before the re-install of Outlook. Help?
D Icloud Outlook 2010 Task/Reminder Search Problem Using Outlook 1
M Problem with meeting requests (default reminder set to 15 minutes by Exchange) Exchange Server Administration 4
B Problem with import Excel BCM (Business Contact Manager) 1
chupacabra Problem with IMAP .pst file Using Outlook 13
deonholt Address Book problem and created new profile ... Using Outlook 1
