VBA Macro to VBScript
Simpler45
Help how to translate all of the code in VBScript
Sub Perenos_Kontaktov_iz_Excel()
Dim objXls As Object
Dim i As Single, j As Single
Dim myNameSpace As NameSpace
Dim myFolder As MAPIFolder, myWorkFolder As MAPIFolder
Dim myOutlook As Outlook.Application
Dim myItems As ContactItem
Set objXls = CreateObject("Excel.Application")
objXls.Workbooks.Open "D:\DataBase.xls"
'укажите путь и имя существующего файла
objXls.Application.Visible = False
Set myOutlook = CreateObject("Outlook.Application")
j = objXls.ActiveSheet.UsedRange.Rows.Count
For i = 1 To j
Set myItems = myOutlook.CreateItem(olContactItem)
With myItems
.FullName = objXls.ActiveSheet.Range("A" & i).Value & " " & _
objXls.ActiveSheet.Range("B" & i).Value & " " & _
objXls.ActiveSheet.Range("C" & i).Value
.Birthday = objXls.ActiveSheet.Range("D" & i).Value
.Email1Address = objXls.ActiveSheet.Range("E" & i).Value
.Save
Next i
Set objXls = Nothing
Set myOutlook = Nothing
I'm not good at localization - I thought the only thing that would need to be changed is the file path - the English functions should work. It doesn't have date and other number formats that would cause issues.
http://www.oaltd.co.uk/ExcelProgRef/Ch22/ProgRefCh22.htm has some information about localizing Excel. It's for an older version but much of it applies to all versions.
If I'm wrong (highly possible :)), where does it error?
J Macro only runs within VBA Editor Outlook VBA and Custom Forms 2
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
M recover deleted items vba macro Outlook VBA and Custom Forms 2
B Outlook vba macro Using Outlook 1
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
N VBA Procedure (or Macro) to Stop Outlook from Closing? Outlook VBA and Custom Forms 2
M Run external program from Outlook VBA macro Outlook VBA and Custom Forms 5
D New Macro / VBA Outlook VBA and Custom Forms 7
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
S macro ist just worling wenn vba editor is open! Outlook VBA and Custom Forms 1
S Excel vba code to manage outlook web app Using Outlook 8
