Reinstalled Outlook 2013 after system crash what is best way to synch with gmail?
jobudge
Outlook 2013 64 bit
What is the best way for me to synch all the folders in outlook 2013 after reinstalling after a system crash with my surface pro 2 using windows 8.1 Do I just click on each folder one by one or is there some setting I can invoke? All my gmail folders are sitting under inbox as subfolders.
I have about 200 folders and 40,000 emails.
Also do the synch while I am on other screens? Seems like whenever I go back to check progress they haven't moved until I click back on Outlook.
L IMAP Folders disappear from Outlook intermittently even when removed and reinstalled. Using Outlook 1
D Outlook 2007 reinstalled, but appointments don't show in To Do bar for new calendar that was created Using Outlook 1
T Reinstalled OL2010 now have 3 separate inboxes and contacts missing Using Outlook 2
P Removed and reinstalled BCM now can't see old .mdf file BCM (Business Contact Manager) 5
P outlook 2008 search box criteria couldn't be saved Using Outlook 1
pcunite Outlook 2019/O365 Build 13127.20408 errors when using MAPI calls Using Outlook 0
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 0
J How do I disable advertising in Outlook 2019? Using Outlook 5
B Outlook Calendar not coming down from cloud Using Outlook 2
J Are the underlined letters in Outlook Reminders window supposed to work? Using Outlook 0
M Office 2016 Outlook is forgetting passwords Using Outlook 14
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 3
G Personal Settings within Outlook Using Outlook 2
V Outlook Forms: Formatting a Label with 2 different styles Outlook VBA and Custom Forms 1
M Outlook 2016 Outlook randomly unhides from taskbar Using Outlook 12
D Sending email from Office 365 alias in Outlook Using Outlook 3
B Spam folder not showing in Outlook Using Outlook 5
ThinkToday Calculate reply time of outlook mail Using Outlook 1
M Microsoft 365 Outlook keeps requesting password on Local Account Using Outlook 1
K Outlook 2016 Outlook, Chrome, and Clio Using Outlook 5
