Research Pane in Emails Turns on and Cut Paste Keys then Stop Working
makinmyway
Outlook 2013 64 bit
When I am working with the cut and paste short cut keys highlighting text from a contact every 30 minutes or so I somehow open the Research pane in an email and then am no longer able to use the shortcut keys in Outlook used to cut and paste. The same shortcut keys work outside Outlook say in Firefox but only by shutting down Outlook and restarting it can I again use the shortcut keys in Outlook. This is very frustrating as I work with Outlook constantly and it's a bother to re-open all of the windows I need open in Outlook.
How can I prevent this from happening? Am I hitting a key stroke combination that is causing this? Alternatively, how can I disable the Research Pane altogether?
Note, I have a Microsoft Sculpt Mobile bluetooth keyboard and it has Window 8 keys as the primary function for all of the F1-F12 keys. To use a typical function key with this keyboard I need to hold the ALT key.
Forum Admin
Just closing the research pane doesn't change the behavior? Are you using Ctrl+X and V for cut and paste or another set of shortcuts?
makinmyway
Outlook 2013 64 bit
Thanks for replying! No, you're right I can close the pane but and I forgot to mention this, once it starts (appears) if I close the pane it reappears if I click anywhere on the body of the email. And yes it's using CTRL+X that seems to do it. That or sliding my mouse down to scroll the text up in the body of an email (that started happening today). It's so confusing. And like I said it only affects Outlook and I can't seem to end the problem until I close Outlook and re-open it again (only to have this happen again within 30 minutes).
makinmyway
Outlook 2013 64 bit
Maybe this has something to do with instructions I have read for opening the Research Pane. Microsoft says to click on a word while holding the ALT key. Maybe I am hitting nearby keys or the keyboard is activating ALT key for some reason?
Forum Admin
I'm assuming that is what you are doing, but I'll see if i can repro. One possibility is that a mouse button is set as Alt and you're bumping that.
makinmyway
Outlook 2013 64 bit
Happened again and I decided to turn off and then back on the bluetooth Microsoft Sculpt Mobile keyboard. Turning it off, reopens the Research Pane! Clearly it's connected to the keyboard. Outlook and this keyboard do not always play well together. I'm not sure there is a solution apart from another keyboard. :(
S Removing "Research" menu item Outlook VBA and Custom Forms 1
B Outlook 365 - Folder pane list clears Using Outlook 24
R Folder pane width change Using Outlook 59
N Wide Line Spacing in Folder pane 2016 Using Outlook 18
GregS What controls content of Folder Pane? Using Outlook 1
A Outlook 2016 Will Not Show Any Data In the People Pane Using Outlook 14
evdbogaard How to dock the Styles Task Pane in the e-mail editing window? Outlook VBA and Custom Forms 1
N Outlook People Pane - Sent Mail Using Outlook 1
Diane Poremsky Outlook's Folder Navigation Pane Disappears New Slipstick.com Articles 2
W Showing more months in the Calendar nav pane Using Outlook 10
H What Controls what is shown in the preview pane Outlook VBA and Custom Forms 1
E Reading Pane has disappeared Using Outlook 1
Diane Poremsky Excel Files Won't Display in Reading Pane New Slipstick.com Articles 1
M Outlook 2007: how to narrow the reading pane and the composing pane Using Outlook 0
L Should public contacts folder appear in "People" nav pane? Using Outlook 1
D Mail accounts don't show up in navigation pane Using Outlook 1
J Copy email from preview pane with headers Outlook VBA and Custom Forms 4
L Navigation Pane selection with shortcuts Using Outlook 2
V Open Outlook Calendar and Tasks views with Folder pane off Using Outlook 2
T Unexpected change of the order of the folders in my navigation pane Using Outlook 6
J Code for new pane to open webpage Outlook VBA and Custom Forms 1
Y (Shared Folder) Using the preview pane to open and close a fax, without opening the email itself Using Outlook 1
T Occasionally, no vertical scroll bar in navigation pane in Outlook 2013 Using Outlook 9
Commodore Difference between Facebook entries in browser vs. people pane Using Outlook 2
Commodore People Pane on a message in 2013 Using Outlook 3
T Outgoing Messages in the Reading Pane Cannot Be Flagged in Outlook 2013 Using Outlook 6
