Outlook problems after yesterday's update
Michael
Updates Office 365 yesterday and Outlook refuses to open: "not responding". Had to do a system restore. Any way to prevent new updates from happening until this gets fixed?
Michael
Thanks for the quick reply, Diane. I am using Windows7 and, though I thought SP1 was already installed, I took a look and it wasn't. So hardware-acceleration may well be the issue (even though it's a pretty new machine). I don't think I'm using aero, but maybe I am...........
The problem isn't so much the machine age but drivers. You don't really need it enabled for the office apps - most computers are powerful but under-utilized and disabling it won't be noticeable.
Michael
Well, I updated again to SP1 and couldn't even open Outlook to see whether the problem was still there. I couldn't open Word or Excel either, so I did a reinstall of the entire suite of programs. All came through as SP1, all of them now opened without a problem, but Outlook still hung on mail or contacts (but curiously not on calendar). So I disabled acceleration and everything seems to be OK for now. Thanks for your help.
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 10
P outlook.com problems Using Outlook 0
D Outlook and Icloud problems Using Outlook 0
E Outlook 2010 network printing problems Using Outlook 4
P Encoding problems after synchronization with Outlook Connector Using Outlook.com accounts in Outlook 6
J problems with viewing aol emails in Outlook Using Outlook 3
B Problems with outlook calendar and android phone syncing calendars Using Outlook.com accounts in Outlook 1
P Sync Problems Outlook with iPad 2 Using Outlook 3
C migrating from Windows Live Mail over to Outlook 2010 Problems ... Using Outlook 2
J Outlook 2010 and Icloud multiple calenders problems. Using Outlook 10
T Outlook 2007 - iTunes - iCloud Sync Problems Using Outlook 7
S Public FolderEmail Sort Problems Outlook 2010/Migration from 2003 SBS to 2011S Using Outlook 3
S Outlook 2010 and certificate problems Using Outlook 9
M Several Problems using Outlook Using Outlook 3
W Outlook exp. 2007 problems - won't receive new mail Using Outlook 1
P Printing problems with MS Outlook 2000 Using Outlook 1
A Two strange calender problems in Outlook 2003 ... Using Outlook 2
T Outlook 2007 shut down problems Using Outlook 1
A Outlook Advanced Search Problems...returns with an Error: Argument Outlook VBA and Custom Forms 1
J Problems with Outlook.Recipient.Resolve Outlook VBA and Custom Forms 3
T Problems re-installing BCM for Outlook 2007 BCM (Business Contact Manager) 2
K Outlook 2019 Randomly Disconnecting from Gmail Servers Using Outlook 5
HarvMan Toggle between calendar and email in Outlook 365 Using Outlook 2
F Email being marked as Spam by Gmail and not being visible in Outlook Using Outlook 3
