IPAD Outlook OWA App - Help using Exchange 2007
JBG
Hi.
I am trying to test out the new Office suite of iPad apps including the iPad Outlook OWA app (Not the web based browser one) and I am having problems.
I am using Office 2010 at work and the company uses Exchange 2007 Server. I do not want to change or upgrade the whole company and am only changing how I work individually.
First of all I need an Office 365 Business account so that is a pain and expensive, but I signed up for a free trial to check things out.
Using OWA though I am trying to setup the Account and our Exchange 2007 (EAS) server. However, it is not working and keeps rejecting the address. I am setting this up online at the Office 365 site. My first question is maybe Exchange 2007 is not actually supported by Office 365 and OWA. Does anyone know this answer?
Assuming is supported then what is the problem? I can use that same server address on my native iPad mail app without any problems and I know that OWA and ActiveSync are all turned on by our IT people.
ANY ADVICE?
JBG
Diane. This takes 15mins from you and 3 Hours on the phone with Microsoft and still no answer! You are the best.
I assume I cannot use Exchange Online individually but would need my whole corporation to switch?
I am trying Touchdown and it is pretty decent. However, I also cannot Sync email Categories with it. I assume that is also a problem with Exchange 2007 not being supported right?
Apparently so, categories do sync with Exchange online, although colors don't. (purple in outlook is red in TD). I don't have a 2007 server to test it with.
Bijan
Outlook 2013 64 bit
Outlook.com (as MS Exchange)
Does the OWA App for the iPad only work with Office 365 Business?
M Outlook and ipad syncing Using Outlook 1
X Problem Transferring Subset of Outlook 2013 Contacts to iPad/iPhone Using Outlook 5
J Can I get real Outlook functionality in an Ipad app? Using Outlook 2
M Outlook 2010 has stopped sinking with my iPhone and iPad Using Outlook 1
I iPad not connecting correctly to Outlook.com account Using Outlook.com accounts in Outlook 7
D Syncing Outlook 2002 with iPad 128 KB Using Outlook 1
P Sync Problems Outlook with iPad 2 Using Outlook 3
C Syncing ipad contacts to Outlook 2007 on my PC Using Outlook 3
T Calendar sync off by 1 hour - outlook 2010 / icloud 2.1 / ipad Using Outlook 2
E Outlook and iPad syncing, IMAP and iCloud Using Outlook 11
R Outlook Connector wont sync with iPhone/iPad Using Outlook.com accounts in Outlook 1
I Not receiving video files sent by iPad Using Outlook 1
Commodore Tasks and iPad Using Outlook 5
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 2
@ Outlook Using Outlook 2
