turnonlegacydialog regedit not working
mr_malkovich
Hey all. I just got Office365 and (one of) the most annoying new features is this infernal Contact Card. I read that this regedit (see jpg) makes it go away but I've noticed no difference after installing it. Restarted the computer and everything. Any advice is appreciated.
mr_malkovich
What I'd REALLY like to do is get rid of the contact card completely. So when I right-click a display name and choose Create Contact or View Contact it goes straight to the regular contact form - well, to be exact, a custom contact form I created. Similarly, when I search People in the search field on the Home ribbon, I'd like the results to summon up the custom form. And really, any other place the contact card shows up.
You can't remove it completely, sorry. Searches can be weird, especially if you have multiple contacts folders - if the form is published to the contacts folder and assigned to the contacts, it *should* come up when you open items, but it can seem a bit buggy.
mr_malkovich
ah well. thanks anyway. in the meantime, any idea why this regedit isn't working for me?
Does it never work or work until you reboot? Did you restart Outlook? (Many keys are only read when outlook loads but i forget if this is one of those keys.)
Did you use the reg file or edit it yourself?
mr_malkovich
Sometimes it works and sometimes it doesn't... It didn't work after I restarted the computer so I reinstalled the regfiles and after a while it kicked in but I restarted again and since then, no dice..
Are you having problems with other settings not working? Is the key getting removed from the registry or is it just not working for some reason?
mr_malkovich
It seems the keys are being removed. I'm looking in Contactcard folder and I see nothing. That's where they're supposed to be, right?
Correct - it's under contactcard - but usually under the policies path
HKEY_CURRENT_USER\Software\Policies\Microsoft\Office\15.0\common\contactcard
mr_malkovich
yep, that's where they seem to be going. but they just disappear after a restart.
if you add it under HKEY_Current_User does it stick? It should be the same under current user and the SID, but the current user key will update the SID.
Do you use a registry cleaner of some sort?
mr_malkovich
Just checked, they were both already in that folder too. Still not working...
Commodore Automatic switch between working offline/online Using Outlook 4
F Searches are not working properly Using Outlook 1
Jennifer Murphy Spam filter not working Using Outlook 13
A calendar invites sent from Microsoft Outlook to Mac Outlook is not working Using Outlook 2
F KB4475563 stops VBS at forms working Outlook VBA and Custom Forms 3
D Archive by receive date not working Using Outlook 2
cricket1001 Shade non-working days in calendar Using Outlook 0
A rules not working Using Outlook 2
V Autocomplete not working on new email account Using Outlook 4
M email search not working Using Outlook 1
J Menus not working BCM (Business Contact Manager) 7
K Working with Explorer.Close event Outlook VBA and Custom Forms 3
A rules (flags) not working Using Outlook 7
P Outlook search is not working at all for Calendar & Tasks Using Outlook 7
D Delay Send not working Using Outlook 3
B Search function in Office 365 has stopped working Using Outlook 3
R When rules are working but invisible and unmanageable Using Outlook 2
C Hyperlinks not working in Outlook Using Outlook 2
M Blocked Sender List @Domain Not Working Using Outlook 0
S Outlook.com Sync working, Sync to Android has issues Using Outlook.com accounts in Outlook 1
S Mail filter recieved before the last 2 working days Using Outlook 1
M Outlook 2016 Rules Not Working Automatically Using Outlook 5
C Outlook 2016 Username Not Working in Scheduling Assistant (Cache Mode) Using Outlook 0
