VBA script to allow mail merges of distribution groups?
mr_malkovich
Hey all. Is there a code that will allow me to mail merge distribution groups? So for instance if I mail merged 20 distribution groups, I'd end up with 20 emails in my outbox, and each would be going to the email addresses assigned to their groups?
Thanks as always..
i don't have any code that does that but i have code that will mail merge to members of a DL - one address per message.
http://www.slipstick.com/developer/mail-merge-members-contact-group/ has normal mail merge behavior of individual messages but uses the members of a contact group (dl) as the source.
Outlook can resolve the group names, so I'd make a text list of the group names and use it as the address source. You need to make sure the names are unique so outlook doesn't resolve them to the wrong person or group.
Well, my initial thought when you first asked was no, but upon further reflection, I think so. I think you'd want to use an outlook form, not a traditional mail merge in word, and copy it using VBA as you send it to each group. Deciding how to pick up the group names would be the hardest part - do you select them in contacts and run the macro, add them to the message you are using as the merge message then break the recipients list up for each message, pick from a list...
mr_malkovich
I like to think I'm good with Outlook, but I understood about 3% of that. When you say use an Outlook form, do you mean a contact form?
Could some kind of app be designed to make this a smooth process? Every day I email a couple of hundred people using mail merge. Some of them need to receive the email individually, and others need to receive it along with a couple other members of their organization. Currently I stop them all in the outbox and go in and manually delete all but one of the emails that are headed to individual members of one company, then manually add their email addresses to the To section of the remaining email then send them all off when I've gone through the whole outbox. Painful.
Sorry about that, I meant outlook mail message. Create the message, add all DLs to the To field then run the macro to copy the message and send it to each group individually.
To use, create a message, enter the Contact groups (or contacts) in the To field then run the macro. Close the original message. put it in thisoutlooksession and add a button to the qat.
http://www.slipstick.com/developer/how-to-use-outlooks-vba-editor/
Sub MailMergeDL()
Dim objItem As Outlook.MailItem
Dim objMsg As Outlook.MailItem
Dim objOutlookRecip As Recipient
Dim Recipients As Recipients
Dim i As Integer
Set objApp = Application
Set objItem = objApp.ActiveInspector.CurrentItem
If objItem.Recipients.Count > 0 Then
  For i = 1 To objItem.Recipients.Count
   Set objMsg = objApp.CreateItem(olMailItem)
   With objMsg
     .HTMLBody = objItem.HTMLBody
     .Subject = objItem.Subject
     .Recipients.Add objItem.Recipients(i)
   For Each objOutlookRecip In objMsg.Recipients
        objOutlookRecip.Resolve
   objMsg.Display ' use Send to send automatically
   Next i
' close the merge message without saving
objItem.Close olDiscard 'use olSave to save it as a draft
Set objItem = Nothing
Set objApp = Nothing
mr_malkovich
Wow. Interesting. Going to carve some time to get to grips with this and get back to you. Thanks as always, Diane.
J Email Parsing VBA Script for Outlook - NEEDED Outlook VBA and Custom Forms 7
R Adding vba to script list Outlook VBA and Custom Forms 4
F VBA script to highlight specific words Outlook VBA and Custom Forms 1
D VBA Script to extract text matching specific criteria Outlook VBA and Custom Forms 1
D VBA script to auto download attachments and rename file according to subject line Outlook VBA and Custom Forms 23
Hudas Outlook VBA script reverting back to previous changes Outlook VBA and Custom Forms 2
V "Accept + Send the Response now", VBA script? Using Outlook 1
R Addins4Outlook TagIt! addin script or VBA module? Using Outlook 2
A VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form Outlook VBA and Custom Forms 2
L Limit VBA Script to one Outlook account Using Outlook 1
