VBA Script to extract text matching specific criteria
Outlook 2013 32 bit
Hi guys,
I'm looking to automate a tedious part of my job. I get incoming requests via email from clients, from which i need to extract text strings and copy them into a new row in a an Excel file, in a particular column (e.g. the next blank row in Column G).
The text strings are always 7 characters long, and are alphanumeric (no special characters). Sometimes they are just text on one line of an email, or in a table, or in an Excel attachment -- simple text or tables are most common, I'm less worried about attached Excel files (though that would be useful too).
An example text string might be: A79R12X
I have an Excel file where I record all these text strings for a given period (usually a financial quarter).
Is it possible for a script to extract every occurrence of those strings? I anticipate that it will catch lots of duplicates (e.g. the same email thread will have the initial text string occurring at the bottom of the chain, so that might get picked up more than once). That would not be hugely problematic -- I would rather the script catch every instance than miss any -- since I can run a macro in the destination Excel file to remove any duplicates.
Cheers!
J Email Parsing VBA Script for Outlook - NEEDED Outlook VBA and Custom Forms 7
R Adding vba to script list Outlook VBA and Custom Forms 4
F VBA script to highlight specific words Outlook VBA and Custom Forms 1
M VBA script to allow mail merges of distribution groups? Using Outlook 7
D VBA script to auto download attachments and rename file according to subject line Outlook VBA and Custom Forms 23
Hudas Outlook VBA script reverting back to previous changes Outlook VBA and Custom Forms 2
V "Accept + Send the Response now", VBA script? Using Outlook 1
R Addins4Outlook TagIt! addin script or VBA module? Using Outlook 2
A VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form Outlook VBA and Custom Forms 2
L Limit VBA Script to one Outlook account Using Outlook 1
