VBA script to highlight specific words
Flatop
Outlook 2013 32 bit
Hello all, is it possible to use VBA to search and highlight specific words in a html Post in Outlook 2010 or 2013? I already have a script that will do this in Word, which I then copy and paste the HTML contents into a new post; however, it would be more efficient if I could just paste the contents into a new post. Then search and highlight with a VBA script from within Outlook instead of having to use Word.
J Email Parsing VBA Script for Outlook - NEEDED Outlook VBA and Custom Forms 7
R Adding vba to script list Outlook VBA and Custom Forms 4
D VBA Script to extract text matching specific criteria Outlook VBA and Custom Forms 1
M VBA script to allow mail merges of distribution groups? Using Outlook 7
D VBA script to auto download attachments and rename file according to subject line Outlook VBA and Custom Forms 23
Hudas Outlook VBA script reverting back to previous changes Outlook VBA and Custom Forms 2
V "Accept + Send the Response now", VBA script? Using Outlook 1
R Addins4Outlook TagIt! addin script or VBA module? Using Outlook 2
A VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form Outlook VBA and Custom Forms 2
L Limit VBA Script to one Outlook account Using Outlook 1
V Modifying the built in forms with VBA Outlook VBA and Custom Forms 3
S Excel VBA and shared calendar issue Outlook VBA and Custom Forms 4
R Limiting length of saved attachment in VBA Outlook VBA and Custom Forms 2
B VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
