Pasting VBA code (and other editing)
Although it's not required to wrap VBA code samples in the code tags, it can make the code sample easier to read and (should) prevent the forum software from munging the code.
You can either type the code tags:
Or use the Insert button to automatically insert the code brackets for you (it opens a window for you to paste the code into). If the Gear icon at the end is gold, you are in BB code editor and need to type the code tags shown above. (Or click the gear icon to switch to this editor and use the menu.)
Philip Rose
Exchange Server 2007
Thank you. I am sorry, I didn't know. Can I edit the submission to put in the tags or do I let it stand?
Philip
Don't worry about it - it just makes it a little easier to read (IMHO). I think you can only edit for like 30 min after posting anyway.
Srinivasan
Outlook 2013 64 bit
how to make to popup message box with the subject "Is all the members in the mail list known to you" , before sending the mail?
Srini
O How to prevent image resize when pasting Using Outlook 2
O pasting text in body of calendar events Using Outlook 5
P Printing, pasting & deleting issues Using Outlook 4
J Pasting into Outlook 2003 produces blue question mark Using Outlook 2
