Outlook 2013 - Default View for Public Folder Contacts
georgebluff
Outlook 2013 64 bit
Recently we just switched from Outlook 2010 to Outlook 2013. I have a few users who are commenting that they cannot change their default view from People to Business Cards. Whenever they change it to Business Cards, click on Mail, then go back to People the view goes back to the people view and doesn't stay with Business Cards. This function works for local contacts as well as public contacts in 2010.
Thank you in advanced!
Forum Admin
What version of exchange server do you use? I'll see if i can repro, but it should stick. In the mean time, have the users reset their view on the folder.
E Outlook 2013 default file error Using Outlook 1
Horsepower How to restore default view Outlook 2013 Using Outlook 8
K Outlook 2013 Multi Accounts set Default different calendar Sender Using Outlook 2
P Outlook 2013 Tasks - default view Using Outlook 1
G Outlook 2013: Cannot Edit default Holiday Calendar Using Outlook 2
D Default Font in Outlook 2013 Using Outlook 3
S [SOLVED] To make Outlook 2013 the default email system Using Outlook.com accounts in Outlook 3
S CHANGE DEFAULT VIEW FOR CONTACT (People) SEARCH - Outlook 2013 Using Outlook 3
T How to change default search engine in Outlook 2013? Using Outlook 3
F Outlook 2013 and default .pst files Using Outlook 1
R Outlook 2013 does not show in default programs - how do I search Using Outlook 1
J Outlook 2013 Change color of text in data fields of contacts in Outlook 2013? Using Outlook 3
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
M OUTLOOK 2013 CONTACT PROPERTIES Using Outlook 0
M Outlook 2013 Using Outlook 1
