Excel Import Option: Need Help Updating Existing Records
KFarchmin
I’m working to clean up my 2010 BCM database and update e-mail opt outs from my Constant Contact account, etc., which is very time-consuming going contact-by-contact.
That being said, I have a long list of opt outs from my Constant Contact account. I would like to go in and update each contact by importing that Excel list into the BCM, and “updating” the existing contacts, and changing their marketing “status” to OPT OUT (a custom field).
From the tutorials I’ve seen and the demonstrations I’ve watched, I think my BCM 2010 is missing the option to “update”. Attached is a screenshot of the import options I'm given.
Even the “help” section of Outlook (http://office.microsoft.com/en-us/o...ontact-manager-HA010379389.aspx#_Toc251157634 ) shows a screenshot with the “update” option. (in attached file).
Can you help? I don’t want to waste my time updating each record if there’s a way to do a bulk edit by importing the list.
  • Import Options for Kfarchmin's 2010 BCM 5-22-2014.pdf
T Outlook Calendar 2016 import Excel Using Outlook 1
B Import Excel Text into Outlook Calender Using Outlook 4
ogodt Change Default contact form and import from Excel 2010 Using Outlook 1
B Problem with import Excel BCM (Business Contact Manager) 1
C Way to import contacts from Excel into BCM Contacts? BCM (Business Contact Manager) 1
N Extract Outlook emails to excel Outlook VBA and Custom Forms 2
C Pull Outlook shared calendars items from Excel Outlook VBA and Custom Forms 4
S How to export urls from email to excel and check the status of the url ? New Slipstick.com Articles 6
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
E Accessing shared outlook folder doesn't work since switch to new outlook/excel Outlook VBA and Custom Forms 11
E Copying the whole e-mail body into excel Outlook VBA and Custom Forms 0
K Update Appointment category when changed in Excel Using Outlook 3
D Paste Excel table into Outlook message Outlook VBA and Custom Forms 6
D Retrieving Tables from outlook to excel Using Outlook 14
nathandavies Email Details to Excel & Save as .MSG on one macro - combination of 2 macros Outlook VBA and Custom Forms 3
N Lookup Value From Excel and Reply With Matching Value Using Outlook 0
D send email from Excel using outlook template Outlook VBA and Custom Forms 3
Diane Poremsky Importing Lists from Excel to Outlook New Slipstick.com Articles 0
N Paste content to Excel when .txt file (attachment) is opened Outlook VBA and Custom Forms 1
M Creating Outlook Appointments from Excel Cells Outlook VBA and Custom Forms 1
M Linking Excel Cell to Shared Contacts Outlook VBA and Custom Forms 7
R Exporting Excel data to Outlook 2016 Calendar Outlook VBA and Custom Forms 20
Diane Poremsky Use a macro to copy data in Outlook email to Excel workbook New Slipstick.com Articles 0
A How to export one email data to excel Using Outlook 1
W macro to export outlook emails to excel Outlook VBA and Custom Forms 6
B Importing Text from Excel to Outlook 2013 Calender Using Outlook 0
A Populate Excel from Outlook Userform Outlook VBA and Custom Forms 3
J Outlook Macro to Update Sharepoint Excel File Using Outlook 1
K Extract email to excel from a specific sender Outlook VBA and Custom Forms 3
