Messages in old PST display as code
LisaW
Exchange Server 2010
I can open old psts in Outlook 2010 and see From, Sent, To, cc: and subject fields fine but the actual message looks like html code. I trying importing the pst to a newly created pst but that didn't work. I don't know what version of outlook was used to create these psts but definitly nothing later than 2003 and perhaps even earlier. Suggestions?
Are all messages affected or just some?
This is with the original pst (or a copy of the original), not the messages after importing them into your current pst? It indicates the message is corrupted - this can happen if antivirus or antispam software scans the email, but it should only be scanned when its downloaded, not when the pst is opened.
I've also seen this happen when importing from OE or Mail, but not with messages that were ok in outlook.
R IMAP & Outlook 2007: incoming messages still going to old Inbox. Using Outlook 3
R Rules - apply to messages > n days old Using Outlook 2
R How to recover old hotmail messages from an .ost file Using Outlook.com accounts in Outlook 3
J Deliver new messages to New or Existing Data File? Using Outlook 2
M Messages Intermittently Dont Arrive In Sent Items After Sending Successfully Using Outlook 4
R Why doesn't outlook use "Normal" style for new messages? Using Outlook 4
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
S Conditional Formatting for messages in a Conversation thread Using Outlook 1
GregS Outlook 2016 Sent Items vs Sent Messages Using Outlook 2
snissen Printing foreign language messages Using Outlook 1
S Receiving duplicate messages from RSS feeds Using Outlook 3
R Can't send messages to groups in Outlook Using Outlook 2
icacream outlook keeps neither SENT or FORWARDED messages... they vanish ! Using Outlook 4
W Receiving messages in offline mode Outlook VBA and Custom Forms 1
RangerRick Text Extraction from forwarded messages external Exchange Server Administration 1
L How to use different fonts for outgoing messages for different email accounts Using Outlook 0
T SMTP messages stuck in Outbox Using Outlook 0
Mark White VBA to deal with Recalled messages Outlook VBA and Custom Forms 7
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
Liza Creating a rule in outlook to filter messages Using Outlook 0
S Automatically selecting folders and deleting messages in Outlook VBA Outlook VBA and Custom Forms 7
Diane Poremsky Save Messages and Attachments to a New Folder Using Outlook 0
P AOL messages Outlook VBA and Custom Forms 0
Diane Poremsky Create a custom field for Outlook messages Using Outlook 0
I Identify Number of email messages opened Outlook VBA and Custom Forms 7
Diane Poremsky Monitor secondary mailbox folder for new messages Using Outlook 0
Diane Poremsky After viewing the Outbox, messages won't send Using Outlook 0
Diane Poremsky Create a Custom Numbering Field for Outlook messages Using Outlook 0
Diane Poremsky Remove Attachments From Messages Using Outlook 0
C Changing the name of Outlook Messages saved to a folder Using Outlook 1
S Outlook 2013 doesn't download html messages Using Outlook 0
