Outlook 2007 Calendar Ribbon has changed and I can't fix it
politzer
When I open an event in Outlook Calendar 2007 I notice that the Ribbon has totally changed and no longer is showing task-related commands, such as notification, day/week/month, and others that had been there previously. I've tried resetting the Ribbon but that doesn't work.
Any suggestions to how I can get back to the normal Ribbon? (I could customize the Quick Access Toolbar, but that would not be my preference).
Mike
Forum Admin
Does it show some calendar commands? Oh wait, an open calendar item won't have day/week/month. THis is the default ribbon for appointments:
politzer
That is absolutely correct. That's the Ribbon I would expect to have and instead I've got some other set of commands, and I can't figure out how to revert back to the default above.
politzer
Here's an event that I opened up. Normally I would expect to see the ribbon above, not this one. As you can see I can't set notification time, save, invite attendees, etc. Weird....
Your appointment tab is missing. Right click on the right end of the ribbon, just after the Symbols section and choose Customize Ribbon. Is Appointments selected? It should be the first one on the list.
politzer
As you can possibly see from the screen print, most of the commands are grayed out. And when I right click on, or outside, the Command Ribbon, I don't get a Customize Ribbon option. Only Customize Quick Access Toolbar option.
Forum Admin
Yeah, you're using Outlook 2007 so the dialogs are different. sorry about that. You may need to delete the UI file - i'll get you the path to it.
politzer
Any update to this? I'd like to fix it if possible.
politzer
Did you see my reply earlier? I still haven't gotten an answer on how to correct this.
R Outlook 2007 calendar colors Using Outlook 15
R Using Internet Calendar in Outlook 2007 within Citrix Using Outlook 1
F Outlook 2007 Calendar Appointments not in Outlook Today view Using Outlook 11
M calendar in outlook 2007 Using Outlook 1
M outlook 2007 calendar Using Outlook 2
J Outlook 2007 Error sharing Calendar: Error while preparing to send sharing message Using Outlook.com accounts in Outlook 2
L Outlook 2007 Calendar Using Outlook 85
O Outlook Calendar 2007 - Invitation Times Using Outlook 19
K Outlook 2007 Calendar - Time spinner does not function correctly Using Outlook 1
V Setting up windows 7 & outlook 2007 w/ Iphone 4 & synch contacts & calendar Using Outlook 9
M sync Outlook 2007 calendar with icloud Using Outlook 1
B Outlook 2007 and Live Calendar Stopped Synching Using Outlook.com accounts in Outlook 4
A Change calendar permissions in Outlook 2007 Using Outlook 9
M Missing Calendar in Outlook 2007 Using Outlook 3
B cant accept iCal calendar invites in Outlook 2007 (SP3) Using Outlook 4
D Calendar Permissions Outlook 2003, 2007 and 2010 Exchange Server Administration 2
M Outlook 2007 Calendar Reminders Using Outlook 1
H Conflicts with other event in calendar ( outlook 2007 & 2010) Using Outlook 0
P Outlook 2007 - Missing Calendar Item Using Outlook 4
P Outlook 2007 - Missing Calendar Item Using Outlook 1
D Outlook 2007 & 2010 calendar permissions Using Outlook 2
D Outlook 2007 - MeetingPlace Express - Calendar error Using Outlook 1
S Calendar sharing problmes between Outlook 2007 & 2010 Exchange Server Administration 0
V Outlook 2007-Tasks not displaying in calendar Using Outlook 4
J Outlook 2007 and 2010 for multiple calendar users Using Outlook 1
B Scheduling a Meeting Resource (Room) with a conflict doesn't indicate any conflict on users calendar in Outlook 2007 Using Outlook 1
P the outlook 2007 calendar cannot be saved because it was changed by another user or in another windo Using Outlook 4
G How re referance a non defualt outlook 2007 calendar Outlook VBA and Custom Forms 3
S Can Outlook 2007 calendar match the Outlook 2003 calendar? Calendar Printing Assistant 3
J Outlook 2007 hangs when Calendar tab is clicked Exchange Server Administration 49
