Looking for Outlook macro to Copy Recipient Names into Email Body
Aussie
Exchange Server 2010
All,
Nice forum ... I am somewhat a newbie ... and I like writing VBA :)
I searched but could not find any VBA to allow me to Copy an email's Recipient Names into the introductory line of the Email Body.
So, for example, when I have added email addresses to the "To:" line:
To: lsywalker@outlook.com, dmaul@outlook.com
I would like to run a macro that adds a line like this to the first line in the body of the email. That is, extract the first names for each contact from the contact list and concatenate them:
Dear Luke, Darth,
And then complete the rest of the body text manually?
Can this be done? Can someone please point me in the right direction (e.g., sample code snippet)
Thanks in advance.
If you are doing a mail merge or are picking up the address from a contact you can insert the contact name. I have samples that do this. If you are just replying, you could use the person's display name (not always the best idea because it might be in last, first order).
Looking up a contact is doable but I'm not sure if i have any code samples that show how.
you'd use something like
Set oContact = colItems.Find("[FullName] = '" & sSenderName & "'")
If Not (oContact Is Nothing) Then
' use something else for the introduction
else
' get the name from the found contact
ocontact.fullname
end if
(the Find snippet is from http://www.slipstick.com/developer/create-contacts-from-messages/ - which checks for contacts before creating one for the sender of a message)
Aussie
Diane ... thanks for the starter code ... I'll see what I can do ...
KoolPal
I've been hunting for this for a long time with no luck! Perhaps now I'll get the solution!!
B Looking for Outlook 2013 update for Send Drafts Macro Using Outlook 4
L Looking for help - want to try an alternative to Outlook? Outlook Wishlist 0
D Looking to move away from exchange to outlook.com Using Outlook 4
O looking to bring in all my folders from Outlook Express (XP) to Outlook 2013 Using Outlook 3
R Outlook Template: Looking to distribute a VBA Outlook template to other people Using Outlook 1
Q Looking for Outlook 2010 Close Event Id Exchange Server Administration 1
S Looking for client-side method (Outlook 2007/Exchange 2007) for users to delete Outlook VBA and Custom Forms 2
P Outlook looking for Copy of Outlook.pst Outlook VBA and Custom Forms 1
G Looking for help with our Organization Forms Library Outlook VBA and Custom Forms 1
peacepanda How to save attachment looking at the attachment name Outlook VBA and Custom Forms 1
M Looking for trainer in Business Contact Manager BCM (Business Contact Manager) 0
B Looking for an add-in or a way to send automatic replies based off a list Using Outlook 2
J Looking for a solution (maybe an add-in) to easily track email conversations Using Outlook 3
I Looking for a productivity add-in similar to "Nostalgy" for Thunderbird Using Outlook 5
C Looking for way to tie a Business Contact to more than one Account BCM (Business Contact Manager) 5
J OL2003 Macro disables itself - looking for way to automate 'enable' Using Outlook 2
R Looking for my BCM backup files BCM (Business Contact Manager) 1
B Looking for email address under ItemSend event Outlook VBA and Custom Forms 6
S Looking for a Utility for Editting An Exported Rules (.rwz) File Using Outlook 6
U looking for feedback on installation process and on eMarking Assis Outlook VBA and Custom Forms 1
K Outlook Office 365 VBA download attachment Outlook VBA and Custom Forms 1
I Outlook is stuck at "Updating Calendar" Using Outlook 1
AmonRa Outlook 365 calendar - too much white space Using Outlook 0
C-S-R How to clear an Outlook (To Do) Task Flag? Using Outlook 8
N How do I make Outlook autocomplete addresses from a list of recognised <full_names> only? Using Outlook 2
P Outlook 2019 UI changes after 20H2 update Using Outlook 1
T The Linked Image Cannot Be Displayed in Outlook Using Outlook 5
A OutLook For Mac 16.46 Comes Up In Small Window When Opening Using Outlook 4
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
Horsepower Moving emails between folder Outlook for Mac Outlook Wishlist 8
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
B Outlook 2016 Outlook crashes when trying to print certain emails Using Outlook 5
T Outlook Template - textbox visible based on combobox selection Using Outlook 1
