pfbackup does not work
useful
I am unable to get pfbackup to work with Outlook 2010.
Having installed it and added the required Registry entry for shutdown notification, I tested it by clicking on the Add Ins Tab in Outlook and selecting Backup, then exiting Outlook and instead of the usual pop-up doing the backup, nothing happens.
I have even tried registering outbak.dll separately and although it registers fine, the backup is still not working.
Does anyone have any ideas?
Thanks in advance
useful
useful
Is the addins staying activated? If you need to reactivate it every time you start Outlook, the problem is that Outlook is disabling it.
Thank you for your response.
The issue has been resolved. I have downloaded the Registry entry, deleted the one I added and installed that one. Although they were the same, the new one works ... go figure.
S Pfbackup with Windows 8 Using Outlook 3
V Outlook 2016 Does Outlook-2016 (64 bit) work with iCloud for Windows ? Using Outlook 4
N Free/busy publish at http location does not work Using Outlook 1
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
E What does mean this icon at the picture attached? Using Outlook 2
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
C Discovery search does not show autoforwarded messages Exchange Server Administration 1
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
Mark Foley Time span on WebDAV published Calendars does not appear to be working Using Outlook 7
snhnic Macro that does not overwrite but add a number Outlook VBA and Custom Forms 1
Rupert Dragwater Deleting email from Deleted Items does not work Using Outlook 0
G Outlook does not show new appointments in To-Do-Bar Using Outlook 0
G Calendar does not point to deafult data file Using Outlook 0
Diane Poremsky What does the "J" mean? New Slipstick.com Articles 0
Christiaan Could not complete operation because the service provider does not support it Using Outlook 2
Simon How does the sender/organizer to dictate the color of a meeting invitation. Using Outlook 3
A Does Outlook import Gmail Archive? Using Outlook 1
1Firefly Outlook 2013 Converstation preview does not show my last reply Exchange Server Administration 1
K CommandButton1 does not respond Outlook VBA and Custom Forms 1
J What exactly does the BCM Database tool actually do? BCM (Business Contact Manager) 3
Alex Hall When updating shared calendar, it does not automatically update personal calendar Using Outlook 3
T outlook 2013 does not mark multiple forward messages as forward Using Outlook 2
M does outlook 2013/365 on mac support custom forms? Outlook VBA and Custom Forms 1
H Outlook.com calendar does not update from Outlook 2013 Home Premium Using Outlook 1
A BCM does not start correctly BCM (Business Contact Manager) 10
