How best to track OUTGOING referrals?
Morgan
Hi, I'm very new to MS BCM.
I need to track referrals and can see that a default Opportunity can be used to track an incoming referral from a third party Account using the "Initiated By" field. However, I also need to track all outgoing referrals.
So if I create a new Opportunity, the "Link to" is my client who I referred, the "Initiated by" is me as the referror. But how do I track it to the third party to whom I referred my client since I cannot put this third party as "Assigned to"?
I am thinking I need to create a custom Opportunity called "Referrals Made/Received" and somehow connect the outgoing referrals to certain Accounts, and somehow be able to see all referrals I made to those Accounts in the Account record and/or in a report.
Thanks in advance for any tips.
Morgan
Hi Diane, thanks for responding. So what I've done is added to the Opportunity form a custom field called "Person referred by/to" as a relationship data type and a destination field name called "Referrals Made/Received (destination record type is All Contact Types for now). This seems to work well. If I refer Joe to Tom, then Tom's Business Contact has a table at the bottom titled "referrals made/received" and shows Joe as a contact who was referred to Tom. I had to create another field called "referral direction" dropdown to show whether Tom referred Joe to me, or I referred Joe to Tom.
The only remaining issue is that the "referrals made/received" table is auto generated and not customizable, so I cannot see the "referral direction" field in the table in Tom's business record. I expect I will be able to generate a report that shows all incoming and outgoing referrals.
Last question: you mentioned needing to make a new opportunity. But as I understand it, we cannot create a "new" separate type of opportunity form, only customize the one standard "opportunity" form. It appears only Accounts, Leads, and Business Contacts can have multiple "types" of forms available (e.g., Clients, Vendors, etc.) . Am I incorrect on that?
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest New Slipstick.com Articles 0
X Best utility for repairing PST files? Using Outlook 3
D a suggestion ...sent with the best intentions Using Outlook 1
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
Horsepower Email best practice Using Outlook 3
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
F Best Non MS Exchange 2010 book for beginners? Exchange Server Administration 7
S CAS/MBX reboot best practices. Exchange Server Administration 7
I Best Practice for Large Messages NDRs? Exchange Server Administration 4
L best rule/macro to send emails from many people/orgs to same folder Using Outlook 3
R Any "Best Practices" for a test/developer Exchange 2010 server? Exchange Server Administration 2
C Best way to effectively back up Outlook Calendar (and save Categories) and Email as well???? Using Outlook 6
R Best practices for creating "Equipment" mailbox resources? Using Outlook 1
D Exchange Best Practice for DEV/TEST/PROD Exchange Server Administration 2
M Exchange 2010: What to monitor - best practices Exchange Server Administration 4
K Best case scenerio to reduce disk space usage Exchange Server Administration 5
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
B Track Record Activity Using Outlook 1
R When rules lose track of "specified folder" Using Outlook 6
