Printing Advanced Search Output Screen
bob.mcc.ct
When I do an Advanced Search>Category I get a list of contacts. If I elect to Print I get a full printout of each contacts information. What I want is just a printout of the information on the Screen - a list of basic Contact info. How do I do this?
Thank you,
Bob
bob.mcc.ct
Thanks for your response. I can't seem to get a "Copy/Paste" option. I tried right clicking on everything on the page. Perhaps I wasn't clear in my description. Let me try again:
1) Outlook 2010
2) In Contacts: Search Tools > Advanced Find > Advanced > Field (Frequently Used > Categories) > Condition (Contains) > Value (XYZ)
3) This brings up a long list of all Contacts (and basic info: Co. Name, Phone #, etc.)
4) I wish to print exactly what I see on the screen - creates a list of contacts for me to use for phone calls (I do not want a printout of the full Contact Info and Notes for each Contact in the list).
I cannot get the "Select All/Copy & Paste" options you noted.
I hope this is a better description of my problem. I know you can do this because I did it once a year or so ago but at age 70 I can't seem to remember how I did it. Funny how this seems to be happening more often of late.
Cheers,
Bob
Sorry about that, you need to use Ctrl+C to copy. Click on one contact to select it then Ctrl+A to select all (or use Ctrl+ the arrow keys to select a few) then Ctrl+C to copy. Use Ctrl+V to paste or the other applications paste command.
In Excel and Notepad, you'll paste a table, word will paste the actual contacts by default (Because of OLE support), so use paste special as text.
tonynap
Outlook 2013 32 bit
Hi Diane. Just to be clear, are you saying that table style is not available for printing multiple items, or only when those items were searched for
Forum Admin
It's just a limitation of Advanced Find. If you use Instant Search and the Phone list (or other table view) you can print a table.
M Printing Appointments Using Outlook 0
M Calendar daily Appointments and printing Calendar Printing Assistant 0
T Printing from Outlook is now defaulting to "Shrink to Fit"! Using Outlook 5
snissen Printing foreign language messages Using Outlook 1
L printing contacts Using Outlook 1
A How to get rid of Contacts field when printing emails? Using Outlook 0
Diane Poremsky Printing Calendars with Color Categories New Slipstick.com Articles 0
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
D Printing Contacts Using Outlook 2
C Printing tasks with multiple categories Using Outlook 5
P Printing PDF attachments of Outlook message attachments Outlook VBA and Custom Forms 2
S macro for opening attachments and printing Using Outlook 1
J Printing Mulitple Calendars Outlook VBA and Custom Forms 1
P printing weekly calendar in Outlook 2013 cuts days of week off Using Outlook 1
M Calendar Printing Assistant Hangs only on specific Template Using Outlook 2
G booklet printing in outlook 2007 Using Outlook 1
W Meeting printing background fields Using Outlook 0
K calendar printing Using Outlook 1
M Outlook 2013 is printing headers only Using Outlook 4
S So Disappointed in Calendar Printing Assistant!! Calendar Printing Assistant 2
D Printing Attachments Automatically in Outlook 2010 Using Outlook 1
F Printing all day events only Calendar Printing Assistant 3
J outlook printing Using Outlook 2
J Printing Calendar in Outlook 2013 Using Outlook 0
C Printing Outlook Form Controls via Word Using Outlook 11
E Printing Using Outlook 1
C Custom .oft / Printing Issue(s) Using Outlook 1
K Printing & Saving Outlook Contacts Using Outlook 3
P Printing Issues in Outlook 2007 Using Outlook 1
E Outlook 2010 network printing problems Using Outlook 4
L Auto printing unread email + attachments in Inbox - Outlook 2010 - (New user) Using Outlook 1
I Printing Using Outlook 0
E Monthly Style Calendar Printing Using Outlook 6
S How to remove tracking from printing - outlook 2010 Using Outlook 4
P Printing calendar (work week) with numerous (i.e. >7) all day events... Calendar Printing Assistant 3
A Outlook CPAO - Printing Monthly calendar with only all day events or catergory Calendar Printing Assistant 2
E Adding Start and End Time to Daily View in Calendar Printing assistant Calendar Printing Assistant 1
M Outlook 2010 task line printing Using Outlook 1
S Printing Selected Date Range in Monthly Style Using Outlook 1
S Does Printing Assistant Work with Windows 8 and Office 10? Calendar Printing Assistant 1
A outlook printing assistant Help editing template Calendar Printing Assistant 3
S Printing Category Key on Calendar Using Outlook 1
P Printing Issue on Calendar Printing Assistant Calendar Printing Assistant 0
W Calendar Printing with Outlook 2010 (64 bit) Calendar Printing Assistant 1
R printing fields in addresses Using Outlook 1
S Nor printing to Epson printer Calendar Printing Assistant 3
R printing custom number of calendar days in weekly view format Using Outlook 1
D Printing Styles No Headers Wanted Using Outlook 1
