How do I remove "Delete Folder" from the right-click menu?
Michael Bauer
In Outlook 2007 that was possible with VBA:
Private Sub Application_FolderContextMenuDisplay(ByVal CommandBar As Office.CommandBar, ByVal Folder As Folder)
CommandBar.FindControl(, 2500).Delete True
In Outlook 2010 the Office.Commandbar still exists but should not be used anymore. The example above doesn't work anymore, at least not on my machine. Test it, maybe it still works for you.
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
T How to remove "automatically delete messages form this sender"? Using Outlook 1
J Can't find, remove or delete defective/bad email address Using Outlook 6
U Can't remove or delete invalid PST file Using Outlook 4
D How to remove a folder, option grayed out Using Outlook 4
B Remove Subject Residual Outlook VBA and Custom Forms 3
R Chancing / remove “ something ” in the subject, online archive Outlook VBA and Custom Forms 8
Morgan Fowler Remove Signature Using Outlook 1
M VBA to remove deferred delivery on a MeetingItem Outlook VBA and Custom Forms 2
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
Diane Poremsky How to Remove RSS Support from Outlook New Slipstick.com Articles 0
Diane Poremsky Remove Attachments From Messages New Slipstick.com Articles 0
Diane Poremsky Remove Office 2013 Update Banner New Slipstick.com Articles 0
O Remove duplicate mail items Outlook VBA and Custom Forms 6
Diane Poremsky Remove a password from an Outlook *.pst File New Slipstick.com Articles 3
L Fake reminder apperaring (not in calendar) - how to remove? Using Outlook 5
J Your IMAP server wants to alert you to the following: cannot remove system folder Using Outlook 3
C how to remove icons on right hand side outlook 2013 Using Outlook 2
K Remove Manage APPS button for users Exchange Server Administration 1
P Remove name and parenthses from email Using Outlook 1
Diane Poremsky How to remove the primary account from Outlook 2010/2013 New Slipstick.com Articles 0
Diane Poremsky Remove an Address from Reply All New Slipstick.com Articles 0
Diane Poremsky Remove Outlook apps from Outlook New Slipstick.com Articles 0
S How to remove forms from Organizational forms library Outlook VBA and Custom Forms 2
2 Task has a strike through but is not complete - how to remove? Using Outlook 1
W URGENT Cancel and remove imported pop3 mails Using Outlook 6
T How to remove annoying Big Blue Type at beginning of my messages Using Outlook 2
H Cannot remove unwanted fields from form Outlook VBA and Custom Forms 9
M How to remove duplicate history items BCM (Business Contact Manager) 7
