Outlook 2013 setup problems
LegalArt
Outlook 2013 64 bit
Glad I found this website. I've installed MS Office Professional Plus 2013 on a new Dell laptop; while attempting to set up the Outlook account, the prompt is asking for the Exchange Server.... I tried server addresses for 2013 and 2010 versions that I found on a MS forum, but the dialog box freezes with those numbers. I also re-installed the software trying to reset it and make it work, but nothing improves. How can I find out what exchange server I have?
Go to Control panel, search for Mail. Open the profile and delete the account or delete the profile and start with a fresh profile. Use the auto account setup wizard to create the account - it looks up the DNS and autodiscover records and creates the correct account type with the correct server names. If that fails, you'll need to get the server name from your Exchange administrator.
L Gmail POP, Android IMAP, Outlook 2013 setup close Using Outlook 5
B New Outlook 2013 setup Using Outlook 8
T Problem With Mail Setup IN Outlook 2013 Using Outlook 2
S Setup many personal calendars on outlook 2013 on new laptop- starting over Using Outlook 1
G Outlook 2013, Windows 8 and Windows Phone 7.5 WP7.5 Setup Using Outlook 11
J Outlook 2013 Change color of text in data fields of contacts in Outlook 2013? Using Outlook 9
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
M OUTLOOK 2013 CONTACT PROPERTIES Using Outlook 0
M Outlook 2013 Using Outlook 1
J Outlook 2013 hanging for unknown reason Using Outlook 1
K Rebuilding Outlook 2013 from Outlook.com after OS rebuild Using Outlook.com accounts in Outlook 2
