Script to move emails to a folder based on various possible keywords
outlookhelp
hi all
i have some code that i need a bit of help with - what i am trying to do is move emails from my Inbox to other folders based on keywords. The code i have moves an email to a folder called TEST if it contains the keyword ala in the subject line - i would like to know how i can add more keywords to the code (for example search for ala or apa or IES Pty Ltd) here is the code i have:
Sub MovePLA(Item As Outlook.MailItem)
With Item
If InStr(1, LCase(.Subject), "ala ") > 0 Then
Item.Move Session.GetDefaultFolder(olFolderInbox).Folders("TEST")
Also is there any way that i can search both the subject and body of the email for those keywords?
Deb
outlookhelp
Great thank you so much that worked ! i now have another little problem though :(
My code picks up the keyword whether it is standalone or whether it is within another word - so if i specify the keyword to be 'ala' it picks up 'ala' but also 'australasian' which is what i don't want. i would like ti to only pick up 'ala' as a standalone keyword . i tried adding a space to the end of 'ala' in the code but that does nothing. So my code is now:
Sub AlaSubject(Item As Outlook.MailItem)
With Item
If InStr(1, LCase(.Subject), "ala") > 0 Or InStr(1, LCase(.Subject), "sos") > 0 Then
If InStr(1, LCase(.Body), "ala") > 0 Or InStr(1, LCase(.Body), "sos") Then
Would you be able to advise how i make that code move only emails with the standalone keywords 'ala' and 'sos' but not words like australasian or sostenuto?
Deb
Michael Bauer
" ala " could do it.
BTW, your could is not what I suggested. Use ElseIf instead of two IFs else it could try to move the same item twice.
outlookhelp
Gosh now it doesn't work at all :( I modified to the following and it doesn't pick up an email with 'this is for people from Chile' in the subject line :( As it's looking for the exact match 'Chile' i thought it should find it and move it to the TEST folder?
Sub MultipleIfs(Item As Outlook.MailItem)
With Item
If InStr(1, LCase(.Subject), "Argentina") > 0 Then
ElseIf InStr(1, LCase(.Subject), "Japan") > 0 Then
ElseIf InStr(1, LCase(.Subject), "China") > 0 Then
ElseIf InStr(1, LCase(.Subject), "Chile") > 0 Then
ElseIf InStr(1, LCase(.Subject), "Spain") > 0 Then
Thank yo so much for your help so far !
Michael Bauer
The LCase function converts a string to its lower cases. And "a..." is not equal "A...". If you pass vbTextCompare as the fourth parameter to Instr, lower cases and upper cases will be treated equally.
outlookhelp
Excellent thank you so much ! It is working perfectly now ! Can i be greedy and last one last question? I now have my script looking for keywods in the subject and body..i have about 100 keywords i need to look up..is there any way that i can do that more efficiently? I don't mind typing out all the code but i am just wondering if there are other functions that may do it better and faster?
This is what my code looks like now for only 5 keywords:
With Item
If InStr(1, LCase(.Subject), "Argentina", vbTextCompare) > 0 Then
ElseIf InStr(1, LCase(.Body), "Argentina", vbTextCompare) > 0 Then
ElseIf InStr(1, LCase(.Subject), "Japan", vbTextCompare) > 0 Then
ElseIf InStr(1, LCase(.Body), "Japan", vbTextCompare) > 0 Then
ElseIf InStr(1, LCase(.Subject), "China", vbTextCompare) > 0 Then
ElseIf InStr(1, LCase(.Body), "China", vbTextCompare) > 0 Then
ElseIf InStr(1, LCase(.Subject), "Chile", vbTextCompare) > 0 Then
ElseIf InStr(1, LCase(.Body), "Chile", vbTextCompare) > 0 Then
ElseIf InStr(1, LCase(.Subject), "Spain", vbTextCompare) > 0 Then
ElseIf InStr(1, LCase(.Body), "Spain", vbTextCompare) > 0 Then
Are they all using the same folder? You can use Select Case or an array to hold the words (and set a folder, if necessary). I'm not sure which is more efficient with that many words - maybe Michael knows. (Or knows of a better way to do it.)
outlookhelp
There are 3 folders:
Gold - 110 phrases and keywords
Platinum - 30 phrases and keywords
Registered - 200 phrases and keywords
Deb
Michael Bauer
I'd do it this way. Set the three folder variables to the target folders, and the keywords for folder(0) to keyword(0), etc. This allows to add more folder/keywords anytime.
dim folder(2) as folder
dim keyword(2) as variant
dim  i as long, y as long
dim s as string, b as string
dim done as boolean
keyword(0)=array(a,b,c)
set folder(0)=....
s=item.subject:b=item.body
for i=0 to 2
  for y=0 to ubound(v(i))
    if instr(1, s,keyword(i)(y),vbtextcompare) then
      item.move folder(i)
      done=true
    elseif instr(1, b,keyword(i)(y),vbtextcompare) then
       item.move folder(i)
      done=true
    endif
    if done then exit for
  next
next
outlookhelp
Great ti will try this out ! Thanks so much for the help - greatly appreciated!
AJBoink
Could someone please help me with a similar code as above? I am new to scripting and i am finding it difficult to understand what different objects or methods are used for; but i am trying to refer outlook vba reference.
Could someone provide me the code for moving a mail (coming from a particular sender) to different folders, and then check the subjects of those mails(the condition has 'AND') based on which they will be moved to different other folders eventually
Diane Poremsky Run a Script Rule: Send a New Message when a Message Arrives New Slipstick.com Articles 2
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
Davzell Change default pop3 account with script, prf or registery ? Outlook VBA and Custom Forms 0
D Script to parse email and set a task Outlook VBA and Custom Forms 1
L Moving Message Class email via script and Rule Outlook VBA and Custom Forms 3
H Customizing "Send to" Attachment Script Outlook VBA and Custom Forms 5
G Script in rule to send to multiple emails found in message bo Outlook VBA and Custom Forms 11
A Creating archive rule on the clients by script/ Outlook VBA and Custom Forms 3
