Problems With Outlook 2013 VBA To Send and Print an email
Horatio_too
Outlook 2013 32 bit
We have a business need to send an email and then print the message once it has been sent.
(We operate in a regulated environment and the sent emails are stored in paper files......)
We initially tried the suggestions from
https://forums.slipstick.com/threads/90476-button-to-send-and-print-emails/
which pointed us in the right direction, but unfortunately did not actually work for us.
However, we DO have some VBA that DOES now work successfully BUT only when it is run in the code window (step-by-step).
If we run the VBA as the users will from a button on the outlook toolbar, then it fails, as the code to print the message is executed before the message is moved from the Outbox to Sent Items.
We have tried Wait statements, loops to check for the existence of the email in Sent Items etc and ALL work fine with the code window open - and all fail "in the real world".
The current code is attached - any help or suggestions gratefully received as always.
Kind regards
Horatio_too
  • OutlookSendAndPrint.txt
Have you tried this timer? - http://www.vboffice.net/en/developers/pause-code-execution
Being the forgetful type, I'd use an ItemAdd macro so i didn't have to remember to use the button. It also insures the correct message is printed. If you don't want to print every message, add a dialog asking if they want to print it.
It lookslike you are checking the subject and to field before sending
If Len(obj.To) > 0 And Len(obj.Subject) > 0 Then
you don't need that with 2010 and 2013 - they check for blank subjects and outlook won't send mail with a blank to field.
Option Explicit
  Dim strDirectory As String
 Private Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliSeconds As Long)
Private Declare PtrSafe Function ShellExecute Lib "shell32.dll" Alias _
  "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, _
  ByVal lpFile As String, ByVal lpParameters As String, _
  ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
 Set Items = Session.GetDefaultFolder(olFolderSentMail).Items
  Dim intUserAnswer As Integer
Dim i As Long
  If TypeOf Item Is Outlook.MailItem Then
  Item.PrintOut
  If Item.Attachments.Count > 0 Then
  Select Case Item.Attachments.Count
  Case 1
  intUserAnswer = MsgBox("There is " & CStr(Item.Attachments.Count) & " attachment to this email. Do you wish to print it ?", vbYesNo)
  Case Else
  'More than one attachment
  intUserAnswer = MsgBox("There are " & CStr(Item.Attachments.Count) & " attachments to this email. Do you wish to print these ?", vbYesNo)
  If intUserAnswer = vbYes Then
  PrintAttachments Item
  MsgBox "The attachments will not be printed"
  MsgBox "There are no attachments."
DeleteFiles
Public Sub PrintAttachments(Mail As Outlook.MailItem)
 Dim colAtts As Outlook.Attachments
 Dim oAtt As Outlook.Attachment
 Dim strFile As String
 Dim strFileType As String
strDirectory = "C:\Users\dianep\Documents\print\"
Set colAtts = Mail.Attachments
If colAtts.Count Then
  For Each oAtt In colAtts
  strFileType = LCase$(Right$(oAtt.FileName, 4))
  Select Case strFileType
  Case ".xls", ".doc", "xlsx", ".pdf", "docx"
  strFile = strDirectory & oAtt.FileName
  oAtt.SaveAsFile strFile
  ShellExecute 0, "print", strFile, vbNullString, vbNullString, 0
  Case Else
  'Do nothing
Public Sub DeleteFiles()
'Call WaitTimer
Sleep 10000
'Delete file from folder
Kill strDirectory & "*.*"
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 3
P outlook.com problems Using Outlook 0
D Outlook and Icloud problems Using Outlook 0
E Outlook 2010 network printing problems Using Outlook 4
P Encoding problems after synchronization with Outlook Connector Using Outlook.com accounts in Outlook 6
J problems with viewing aol emails in Outlook Using Outlook 3
B Problems with outlook calendar and android phone syncing calendars Using Outlook.com accounts in Outlook 1
P Sync Problems Outlook with iPad 2 Using Outlook 3
C migrating from Windows Live Mail over to Outlook 2010 Problems ... Using Outlook 2
J Outlook 2010 and Icloud multiple calenders problems. Using Outlook 10
T Outlook 2007 - iTunes - iCloud Sync Problems Using Outlook 7
S Public FolderEmail Sort Problems Outlook 2010/Migration from 2003 SBS to 2011S Using Outlook 3
S Outlook 2010 and certificate problems Using Outlook 9
M Several Problems using Outlook Using Outlook 3
W Outlook exp. 2007 problems - won't receive new mail Using Outlook 1
P Printing problems with MS Outlook 2000 Using Outlook 1
A Two strange calender problems in Outlook 2003 ... Using Outlook 2
T Outlook 2007 shut down problems Using Outlook 1
A Outlook Advanced Search Problems...returns with an Error: Argument Outlook VBA and Custom Forms 1
J Problems with Outlook.Recipient.Resolve Outlook VBA and Custom Forms 3
T Problems re-installing BCM for Outlook 2007 BCM (Business Contact Manager) 2
