Creating a URL from a message body excerpt before forwarding
Joerg
I would like to ask for help on the following:
I am getting e-mails with a standardized format eg
Event Number: 123456
Date: 08/01/2014
Customer: ABC
Event Narrative: xyz
The event number is a unique identifier in another system and added to a standard URL prefix, this becomes a link that can go directly into the system e.g. https://forums.slipstick.com/123456
I would want to forward the initial message, merge the event numbervwith the link prefix and embedd the full link into the forwarded message.
In a perfect world, the event number in the original message would be fitted with that link:
Date: 08/01/2014
Customer: ABC
Thanks so much in advance for your feedback!
As long as the event number is always identified as such, you can use regex to grab it - http://www.slipstick.com/developer/regex-parse-message-text/ - then put it together as strURL = http://domain/ & M.SubMatches(1).
Putting it together with code link this to create a hyperlink is a little harder, but doable as long as the messages are in html format.
<a href="https://forums.slipstick.com/123456">https://forums.slipstick.com/123456</a>
Joerg
Thanks Diane. I am honoured to get feedback by THE Master. Please give me a few days to explore this - not an expert on VBA so I have to dig through some other material to get this done.
Thanks again,
Joerg
R Creating a user defined function Outlook VBA and Custom Forms 3
O How to prevent CC from showing when creating a new mail? Using Outlook 1
N Creating a button or link to a form in the Organizational Forms Library Outlook VBA and Custom Forms 3
B Creating an email with the list of tasks Outlook VBA and Custom Forms 0
L Creating drafts when I thought I was sending Using Outlook 1
R Would creating a new profile cause Outlook to download all the old mails from the server? Using Outlook 1
A Creating Progress Bar or Status Bar Update Outlook VBA and Custom Forms 0
T Outlook creating a folder named: "Unwanted" Using Outlook 3
Liza Creating a rule in outlook to filter messages Using Outlook 0
S Creating Email - Selecting Pre-Defined Text Using Outlook 2
M Creating Outlook Appointments from Excel Cells Outlook VBA and Custom Forms 1
N Creating New Profile Using Outlook 0
M creating email from contact file = 3 emails in To field Using Outlook 3
P Recover / Extract Rules from standalone PST file creating RWZ file Using Outlook 2
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
I Creating meeting invite with disabled tentative button Outlook VBA and Custom Forms 5
E Creating email templates for organizational use Using Outlook 0
D Creating custom view with VBA Outlook VBA and Custom Forms 2
J Outlook creating unwanted rule on its own Using Outlook 1
R Creating a Room Mailbox with Exchange Online Outlook VBA and Custom Forms 0
A Creating a rule on “Deleted items” folder Using Outlook 1
CMG73 Creating templates with predefined subject and CC Using Outlook 1
G Creating Contact Sub Folders Using Outlook 2
Rupert Dragwater creating gmail account in Outlook 2013 Using Outlook 7
nathandavies Creating a Select Case for a directory of folders Outlook VBA and Custom Forms 1
2 creating custom stationery Using Outlook 2
A Help creating macro for conditional formatting settings Using Outlook 8
Fozzie Bear Creating Custom Meeting Form Outlook VBA and Custom Forms 6
U Creating a (This computer only) folder within an IMAP account directory Using Outlook 1
A Creating archive rule on the clients by script/ Outlook VBA and Custom Forms 3
A Creating rule to create week folder and transfer mail using alert Using Outlook 3
J Creating an "isolated" shared calendar in Outlook Outlook VBA and Custom Forms 1
L Creating a Task from Email and Attaching Original Email Outlook VBA and Custom Forms 6
S Creating custom rule to move if "NAME" is in body but ignore the phrase "Hi NAME" in the search Using Outlook 2
witzker Outlook bug when creating a user defined contact form? Using Outlook 1
G Creating an Outlook Rule using Internet Header time Using Outlook 1
Wotme Creating a Outlook task in Excel Using Outlook 7
V Need to add some text in subject while creating new mails - NEED VB CODINGS Using Outlook 4
G Questions on creating Outlook forms Using Outlook 0
P Creating custom contact forms Using Outlook 2
K Outlook 2010 creating extremely large PST files for IMAP accounts Using Outlook 3
J Troubleshooting Creating New Outlook Account Using Outlook 1
