Can I Search for Contacts by Addresses within a Proximity?
makinmyway
Outlook 2013 64 bit
I am using Windows 8.1 and Outlook 2013 and wonder if there is a way to search for contacts that are within a range of another address by miles. Perhaps this is in the form of an add-on that someone has heard of before. I know I can search by zip codes and cities but that leaves out many contacts in results. Ideas?
makinmyway
Outlook 2013 64 bit
Oh but still that is good information to know. I will search online for something outside of Outlook. Thanks, Diane!
M how to speed up search of shared contacts Using Outlook 0
A "search people" not finding all contacts Using Outlook 17
L Outlook 2007 Search All Fields in Contacts Using Outlook 1
S Contacts disappear in public folder search Using Outlook 1
L Outlook 2007 Macro Search Contacts Using Outlook 9
S "Search People" sometimes shows contacts 2 different ways - Outlook 2013 Using Outlook 6
D Search iCloud contacts from Outlook 2010 CTRL-E Using Outlook 4
M Unable to search Note section in Contacts in icloud Using Outlook 7
T Search for multiple contacts in OL2007 Using Outlook 3
V No results when I SEARCH contacts under COMPANY NAME . . . . Using Outlook 3
T search contacts by domain name Outlook Wishlist 1
S Outlook 2010: How do you enable Contacts' Activities to search archive folders Using Outlook 6
andyzack Unable to search for Contacts in Tasks? Using Outlook 5
J How can I search my contacts by where businesses are located? BCM (Business Contact Manager) 2
J outlook 2007 doesn't let me choose which .pst to search Using Outlook 1
L New Location for the Search Bar Using Outlook 6
King Mustard Sort search groups by amount of items? Using Outlook 1
T Search for incoming e-mails for a specified time range Using Outlook 1
R Search/Jump to a folder by typing its name Outlook VBA and Custom Forms 1
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
W Search Incomplete Outlook 2016 Using Outlook 5
R outlook address book search broken Using Outlook 2
R What's supposed to appear when just clicking into the search field? Using Outlook 7
B Instant search with special characters Using Outlook 1
A Search folder refresh Outlook VBA and Custom Forms 3
M email search not working Using Outlook 1
F Search folder for tasks in all task folders Using Outlook 1
B Search: Cannot find which Folder Contains a Message Using Outlook 3
