Recent Files Not Updating when Using Insert Hyperlink in Outlook 2013
makinmyway
Outlook 2013 64 bit
I am using Outlook 2013 in a Windows 8.2 environment and the Recent Files list when using the Insert Hyperlink function is no longer working. It's worked for and think it still works sporatically but the list is not up to date. In the past it would update if I downloaded a file to my hard drive and saved it say in MS Word or Adobe Acrobat. Now the list is still there but it's all old stuff.
Is there something I need to do to get it to start work again? Ideas?
V Pin a document to the "Attach file" Recent Documents list Using Outlook 0
A Order of Recent Items in Attach File List Using Outlook 5
O See recent emails from a sender Using Outlook 2
M Recent emails disappearing Using Outlook 4
C connecting to recent outlook file on new hard drive Using Outlook 2
D Outlook 2010: Conversations view - most recent activity posts to of inbox? Using Outlook 2
B Having Recent Issues with Hotmail Connector? Using Outlook.com accounts in Outlook 17
T OWA 2007 recent recipients and OWA 2010 nicknames Exchange Server Administration 5
J Sent Items Folder Isn't Showing the Most Recent Sent Items Using Outlook 7
N pst files are recreating automaticaly and cannot be deleted Using Outlook 5
N Two .pst files on one computer both with contacts? Using Outlook 9
V Carbonite not backing up .ost files Using Outlook 7
DoctorJellybean Import accounts\files Using Outlook 1
O Outlook 2016 has "Outlook 2015" files Using Outlook 2
R How can I access my emails from corrupt offline files of MS Outlook ? Using Outlook 1
O Any decent tool to compare .pst files? Using Outlook 2
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
S Dragging Files In Outlook 2016 Using Outlook 6
M Multiple spurious empty folders appear in archive files Using Outlook 3
O Merge .pst files (without structure) Using Outlook 7
B Delete/replace old files and save new attachments Using Outlook 1
R Lost PST files after format Using Outlook 6
Diane Poremsky Rename Email Accounts and Data Files in the Folder List New Slipstick.com Articles 0
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
Kika Melo Change location of Outlook SecureTemporary Files Folder Using Outlook 5
A UID field in iCal files - unique per-event or per-user or both? Using Outlook 2
I Windows 10 - .msg files on disk show Explorer popup error Using Outlook 5
I Not receiving video files sent by iPad Using Outlook 1
B Deleting old Stream_autocomplete and other files Using Outlook 1
fitzgerald Lost PST files after format - how to recover deleted files? Using Outlook 3
P Excel 2010 can't open .xlsx files Using Outlook 1
K Cannot consistently drag and drop .msg files into Outlook 2010 Using Outlook 0
Diane Poremsky Excel Files Won't Display in Reading Pane New Slipstick.com Articles 1
S Repair corrupt .PST & .OST files Using Outlook 5
V data files cannot be opened Using Outlook 4
Z Importing PST files from Outlook 07 to Outlook mac Preview Using Outlook 1
J Using 2003 .pst files w 2013 Using Outlook 1
Diane Poremsky Use a Macro to Attach Files to New Messages New Slipstick.com Articles 0
