Vba script including macro appears in rules but wont run
Paul Fone
Hi there
Here is a script for Outlook 2010 to click on the first hyperlink in an email. It shows up as a script in the rules in outlook - the macro appears in the developer tab in Macros and runs fine but it will not trigger live. Any help would be much appreciated
'Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Sub LaunchURL(Itm As Outlook.MailItem)
Set objOL = Application
Set objDoc = objOL.ActiveInspector.WordEditor
Set objSel = objDoc.Windows(1).Selection
objDoc.Hyperlinks(1).Follow
Set Itm = Nothing
Set objOL = Nothing
Set objDoc = Nothing
Set objSel = Nothing
Sub LoopThruEmails()
Dim i As Long
Dim InboxItems As Outlook.Items
Dim thisEmail As Outlook.MailItem
Set InboxItems = GetItems(GetNS(GetOutlookApp), olFolderInbox)
' assume there are inbox items
For i = InboxItems.Count To 1 Step -1
If TypeName(InboxItems.Item(i)) = "MailItem" Then ' it's an email
Set thisEmail = InboxItems.Item(i)
thisEmail.Display
' Sleep (3000) ' wait 3 seconds
Dim currItem As Outlook.MailItem
Dim Insp As Outlook.Inspector
Set currItem = Application.ActiveInspector.CurrentItem
LaunchURL currItem
thisEmail.Close olDiscard
Next i
Function GetOutlookApp() As Outlook.Application
' returns reference to native Application object
Set GetOutlookApp = Outlook.Application
End Function
Function GetNS(ByRef app As Outlook.Application) As Outlook.NameSpace
Set GetNS = app.GetNamespace("MAPI")
End Function
Function GetItems(olNS As Outlook.NameSpace, folder As OlDefaultFolders) As Outlook.Items
Set GetItems = olNS.GetDefaultFolder(folder).Items
End Function
Regards Paul Fone
This line: Sub LaunchURL(Itm As Outlook.MailItem) tells it to only work when called by a rule or another script.
You need something like this to run it manually
Sub LaunchURL()
dim Itm As Outlook.MailItem
set itm = objOL.ActiveExplorer.Selection.Item(1)
Paul Fone
I actually want it to run automatically using a rule but it doesn't work
Regards
Paul Fone
Michael Bauer
If run automatically by a rule, the rules passes a ref on the newly added item. Instead of using that one, you try to follow a link in the body of the current open email, see this line:
Paul Fone
Hello Michael
I am a real novice at this so could you please explain where I place this line or what is my next step?
J Email Parsing VBA Script for Outlook - NEEDED Outlook VBA and Custom Forms 7
R Adding vba to script list Outlook VBA and Custom Forms 4
F VBA script to highlight specific words Outlook VBA and Custom Forms 1
D VBA Script to extract text matching specific criteria Outlook VBA and Custom Forms 1
M VBA script to allow mail merges of distribution groups? Using Outlook 7
D VBA script to auto download attachments and rename file according to subject line Outlook VBA and Custom Forms 23
Hudas Outlook VBA script reverting back to previous changes Outlook VBA and Custom Forms 2
V "Accept + Send the Response now", VBA script? Using Outlook 1
R Addins4Outlook TagIt! addin script or VBA module? Using Outlook 2
A VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form Outlook VBA and Custom Forms 2
L Limit VBA Script to one Outlook account Using Outlook 1
