Change Default View - Color and font
Jim Nolte
Outlook 2013 64 bit
Exchange Server 2013
I have developed vision problems and reading my email in the light blue default settings is very difficult. THis is mainly the inbox. Going to black and white would be ideal, but I have not been able to locate the settings, if they can be changed?
The zoom slider might be helpful, but this feature does not slide in the RH corner. Individual emails can be read, it is the inbox view that is most difficult to read. Any suggestions would be greatly appreciated. Thank you.
The font change be changed - it's in View settings on the View tab, under Conditional format. Change the colors for the read and unread conditions. Also, you can change the font used for the columns in Other Settings.
The zoom slider keeps resetting to 100% each time you change the message. There is an addin and a macro that can increase it when you open messages but it doesn't work in the reading pane.
http://www.slipstick.com/outlook/adjust-outlooks-zoom-setting/
Laurel
Outlook 2016 64 bit
Hi Diane, I have an odd problem. Brand new desktop, Win10, Office365, Outlook16. When I open Outlook, preview pane is crisp, clear text. But when I write an email, or read an email, text is distorted. Others say it is not distorted when they receive my emails, but it is driving me crazy. It is set at Calibri Regular 12. Any suggestions as to how to fix this??? I would be very grateful
In what way is it distorted? Can you post a screenshot?
S CHANGE DEFAULT VIEW FOR CONTACT (People) SEARCH - Outlook 2013 Using Outlook 3
M Change default Current View on People Using Outlook 1
G how to change default calendar view to show this week and future weeks? Using Outlook 1
J How To Change Default View of Tabs in Outlook 2010 Using Outlook 4
C Change default colors for conditional formatting Using Outlook 2
Diane Poremsky To Change the Default E-mail Program in Windows New Slipstick.com Articles 0
L Change default from english to danish ...... Using Outlook 5
Davzell Change default pop3 account with script, prf or registery ? Outlook VBA and Custom Forms 0
Diane Poremsky Change the All Day Event Default Free/Busy to "Busy" New Slipstick.com Articles 3
M Change default "automatically test account settings when Next is clicked" Using Outlook 1
David Rahrer Change default Junk E-Mail folder Using Outlook 6
C Change the default sent folder Outlook VBA and Custom Forms 1
JulieB Default data file won't change Using Outlook 6
ogodt Change Default contact form and import from Excel 2010 Using Outlook 1
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
B Change default email for address book Using Outlook 1
C Change default reminder time for contacts Using Outlook 2
T How to change default search engine in Outlook 2013? Using Outlook 3
J How to change my default calendar...? Using Outlook 1
H Outlook default landscape need to change to portrait Using Outlook 1
K Change the default Archive location via GPO in Outlook 2010 Using Outlook 3
F Change default value of date/time type from "None" to Blank Using Outlook 1
G Default Account Change Using Outlook 5
O Exchange + pst: Can I change the default Outlook calendar/tasks/account? Exchange Server Administration 2
S change default contact list in Outlook 2010 to "contacts" rather than "global" Exchange Server Administration 1
M How do I change the default map from Bing to Google in Outlook 2003? Using Outlook 23
K Change default "Display As" for contact email addresses Using Outlook 1
H How to make hourglass and change back to default in Outlook class ? Outlook VBA and Custom Forms 3
D How to change account used for replies from default Outlook VBA and Custom Forms 7
C How do I change the default "Add to Outlook Contacts" Folder Using Outlook 6
D RE: How do you change the default insert file path in outlook? Using Outlook 11
V change the Default email Delivery Location Outlook VBA and Custom Forms 3
C How do I change the default character spacing in Outlook e-mail? Using Outlook 3
M Default settings for "Display as" Change? Outlook VBA and Custom Forms 8
R How to Change Margins In Google Docs...? New Slipstick.com Articles 0
D Change senders title Using Outlook 1
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
