Looking for Outlook 2013 update for Send Drafts Macro
Bren
Outlook 2013 64 bit
Exchange Server 2010
Does anyone know of a way to get this macro to work in Outlook 2013 or do you have suggestions for a new method? We're currently using it in Outlook 2003 to send multiple e-mails from our Drafts folder.
Public Sub SendDrafts()
Dim lDraftItem As Long
Dim myOutlook As Outlook.Application Dim myNameSpace As Outlook.NameSpace
Dim myFolders As Outlook.Folders
Dim myDraftsFolder As Outlook.MAPIFolder
'Send all items in the "Drafts" folder that have a "To" address filled in.
'Setup Outlook
Set myOutlook = Outlook.Application
Set myNameSpace = myOutlook.GetNamespace("MAPI")
Set myFolders = myNameSpace.Folders
'Set Draft Folder.
Set myDraftsFolder = myFolders("SC").Folders("Drafts")
'Loop through all Draft Items
For lDraftItem = myDraftsFolder.Items.Count To 1 Step -1
'Check for "To" address and only send if "To" is filled in.
If Len(Trim(myDraftsFolder.Items.Item(lDraftItem).To)) > 0 Then
'Send Item
myDraftsFolder.Items.Item(lDraftItem).Send
Next lDraftItem
'Clean-up
Set myDraftsFolder = Nothing
Set myNameSpace = Nothing
Set myOutlook = Nothing
Bren
Outlook 2013 64 bit
What happens when you try it? It's pretty basic and should work with outlook 2013.
We were able to get it working today, without making any changes. All we needed was the threat of your help (it's like what happens when your appliances stop working until the very second that a repairman sets foot on your premises. lol)
I'm not sure if that's good or bad. LOL
Was the problem with macro security settings? That's a common cause with new setups.
Bren
Outlook 2013 64 bit
No, our Security settings were fine. It would run for our personal mailboxes but wouldn't run for our group's functional mailboxes. It would run fine with both types of mailboxes in Outlook 2003 but wouldn't in Outlook 2013. Same code. We wouldn't get error messages---it would just hang. Finally I just deleted the code (again, for like the 10th time) and this time it worked.
O looking to bring in all my folders from Outlook Express (XP) to Outlook 2013 Using Outlook 3
D Looking to move away from exchange to outlook.com Using Outlook 4
Aussie Looking for Outlook macro to Copy Recipient Names into Email Body Outlook VBA and Custom Forms 3
R Outlook Template: Looking to distribute a VBA Outlook template to other people Using Outlook 1
Q Looking for Outlook 2010 Close Event Id Exchange Server Administration 1
S Looking for client-side method (Outlook 2007/Exchange 2007) for users to delete Outlook VBA and Custom Forms 2
P Outlook looking for Copy of Outlook.pst Outlook VBA and Custom Forms 1
G Looking for help with our Organization Forms Library Outlook VBA and Custom Forms 1
peacepanda How to save attachment looking at the attachment name Outlook VBA and Custom Forms 1
M Looking for trainer in Business Contact Manager BCM (Business Contact Manager) 0
B Looking for an add-in or a way to send automatic replies based off a list Using Outlook 2
J Looking for a solution (maybe an add-in) to easily track email conversations Using Outlook 3
I Looking for a productivity add-in similar to "Nostalgy" for Thunderbird Using Outlook 5
C Looking for way to tie a Business Contact to more than one Account BCM (Business Contact Manager) 5
J OL2003 Macro disables itself - looking for way to automate 'enable' Using Outlook 2
R Looking for my BCM backup files BCM (Business Contact Manager) 1
B Looking for email address under ItemSend event Outlook VBA and Custom Forms 6
S Looking for a Utility for Editting An Exported Rules (.rwz) File Using Outlook 6
U looking for feedback on installation process and on eMarking Assis Outlook VBA and Custom Forms 1
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 2
@ Outlook Using Outlook 2
