Trouble Starting Outlook 2010 after Crash
B Parker
Short version of the problem - I left my computer running with Outlook 2010 active. Returned to find that the computer had crashed. Restarted to the Blue Screen of Death, ran BIOS diagnostics found corrupted memory addresses. Replaced RAM. Booted up fine however had numerous software issues with the Windows 7 Pro installation - no WIFI, or LAN driver, no command prompt, etc.
Had a local Computer Shop perform diagnostics/repair of Win7. All seems fine.
However, when I attempt to open Outlook 2010, it returns with the error:
"Cannot Start Microsoft Outlook. Cannot open the Outlook window. The set of folders cannot be opened. The file C:\Users\<user name omitted in this thread>\AppData\Local\Microsoft\Outlook\<email address omitted in this thread>.ost cannot be accessed. You must connect to Microsoft Exchange at least once before you can use your Outlook data file (.ost)."
I have gone to that address and the named .ost file does exist. I've tried opening that .ost file using Open With and naming Outlook as the program to use. I've used IE to open the named outlook.com address and it opens fine inside IE, but that didn't resolve the issue.
I'm stumped.
Any suggestions?
PS - I am not a business user, so I do not have outlook open a VPN, however I do have a several outlook.com account which I sync emails/contacts/calendars through.
Thanks for your time.
Forum Admin
I'm guessing there is some corruption in the ost file. Remove the email account from your profile and add it back - it will create a new ost file.
B Parker
It seems I wasn't clear about something - Outlook won't start, it errors out with that error message and doesn't open.
Therefore, I cannot remove the email from my profile.
B Parker
I've attempted a re-start by deleting the .ost file, but it gives me another error message about that file being not found and again, fails to start.
G Trouble with Office 365/2016 Using Outlook 3
M Trouble downloading Outlook on an Android phone Using Outlook 4
U Trouble migrating Contacts (2002) to People (2013) Using Outlook 3
K New to BCM - trouble importing contacts & accounts BCM (Business Contact Manager) 3
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
M Trouble Importing folders from Outlook 2007 to Outlook 2013 Using Outlook 12
B Trouble Locating Tools Menu since There's No Standard Toolbar in Office 2010 Using Outlook 1
T Outlook 2007 - trouble with alphabetizing when titles are used (ie - Mr.) Using Outlook 0
M Outlook 2010 stuck in Work Offline mode; trouble sending email Using Outlook 1
B Trouble Adding @Outlook.com Email Accounts Using Outlook 3
K Trouble converting the ANSI PST to a Unicode PST Using Outlook 4
U Trouble for sharing Calendar Using Outlook 3
S Trouble setting up Outlook Connector to sync with windows live Using Outlook.com accounts in Outlook 3
N Trouble importing calender information from iPhone into OutLook 2010 Using Outlook 1
J TROUBLE SENDING EMAIL FROM OUTLOOK, NO PROBLEM RECIEVING WHEN WORKING FROM OUT OF TOWN Using Outlook 1
T Trouble with creating database BCM (Business Contact Manager) 1
M having trouble importing excel data into outlook contacts BCM (Business Contact Manager) 1
K Trouble using SaveAs Outlook VBA and Custom Forms 3
M trouble connection to remote database BCM (Business Contact Manager) 1
G Rule starting a VB macro against incoming email Outlook VBA and Custom Forms 3
S Setup many personal calendars on outlook 2013 on new laptop- starting over Using Outlook 1
N Starting out with BCM - Customizing contact records BCM (Business Contact Manager) 1
B Starting up outlook in Windows 8 Using Outlook 2
K Starting Outlook 2013 x64 minimized in Win 8 with or without Task manager Using Outlook 5
V Starting Fresh with a new PST file. Using Outlook 0
D Starting Outlook 2K3 without e-mail support Using Outlook 4
S Starting outlook in imap Inbox Using Outlook 7
C starting Outlook 2003 sp3 sets Junk Email setting to 'No automatic filtering' Using Outlook 3
T Click "A" to see all email from people with names starting with A... etc Using Outlook 3
J Problems starting Information Store Server in Exchange 2003 Exchange Server Administration 13
E Why does a Mailboximportrequest queue for at least 10 minutes before starting the import? Exchange Server Administration 1
S Error starting MS Outlook - Problem Event Name CLR20R3 Using Outlook 2
C Starting a new .pst file Using Outlook 1
B Outlook 2010 cannot get past Loading Profile when starting Using Outlook 3
D Starting Outlook - Stuck on processing, search folder as default "start Outlook in this folder" Using Outlook 1
M Exchange 2010 Services are not starting automatic on startup Exchange Server Administration 39
C Starting out and would like advice Outlook VBA and Custom Forms 1
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
M outlook 365 trying to finish my sentences Using Outlook 0
D Outlook Address Book Using Outlook 0
