How to restore default view Outlook 2013
Horsepower
Outlook 2019 for Mac
Outlook.com (as MS Exchange)
This morning I inadvertently click somewhere in the message list and it shrunk and diffused all message in all folders. How can I restore default VIEW? Thank you.
Did you click on the triangles next to the folder names? If that is not the problem, can you post a screenshot?
If all else fails ,you could restart outlook with the /resetnavpane and again using /cleanviews but both are nuclear options and will wipe out customizations.
Horsepower
I clicked somewhere in a message and it changed the whole thing. I did try the "cleanviews" option. Then I went and tried a bunch of things to get it back and dug the hole deeper (I think). Outlook 365 home subscription, Windows 8.1.
it looks like the reading pane is narrow or off, otherwise looks normal. <g> if the navigation pane on the left is missing, Alt+F1 will cycle it back.
The compact view of the message list kicks in when the message list is no more than 100 px wide - pull the bar to the right of the scrollbar to the left to make it narrower (and make the reading pane wider.)
Horsepower
Well, 3 times Alt+F1 returned it (thanks), all that is left is I do not know why when I reply "file" instead of "message" is highlighted. I can easily click "message" to get the send option, but it used to be in "message" mode by default.
You have the ribbon minimized? File isn't selected, its just darker.... confuses the heck out of everyone.
Horsepower
It's ok when I create a new message, but when I open a message it looks like this by default and I have to click "message" to get the option to reply.
Yeah, it's minimized. You can add the Reply button to the QAT or use Ctrl+R - or double click on the Message 'tab' so it stays open (or right click and click on Collapse the ribbon to remove the checkmark from it)
Horsepower
Awesome, thanks. I cannot believe I messed up with a couple of clicks the other day. I guess in the old days I was nimble fingers, now I must be nimble clicker...
wallisellener BCM - restore default settings BCM (Business Contact Manager) 36
P Restore an individual all-day recurring event Using Outlook 2
J How to restore field no longer visible in field chooser? Using Outlook 1
S How to restore corrupted PST file over 2GB in Outlook 2007 Using Outlook 2
G pst file restore Outlook 2013 from HTC One M9 Using Outlook 1
K After Carbonite restore pst files are found in a weird location Using Outlook 2
M Is it possible to restore deleted webmail to server? Using Outlook 3
B How to restore a Contacts Group back into the Contacts list Using Outlook 1
C Custom Search Folders deleted, /resetnavpane, can i restore? How? Exchange Server Administration 1
B Restore deleted contact distribution list Using Outlook 1
E Birthdays & Holidays in ICloud, how to restore them to Outlook Using Outlook 2
D Restore Delete Calendar Meeting Request Using Outlook 3
J Outlook client not redrawing completely upon restore Using Outlook 0
I Restore Outlook 2010 from iCloud Using Outlook 2
R Restore Master Category List Outlook 2013 Using Outlook 7
O BCM Dbase Issues (both not seeing dbase & not allowing restore for wrong owner BCM (Business Contact Manager) 2
M Outlook 2003: Restore location Using Outlook 1
E Disappointed in Outlook 2007, backup, restore, synch Using Outlook 5
E Outlook 2007 backup and restore function Using Outlook 2
P How to restore my previous address book after an iPhone sync changed it Using Outlook 2
M My Contacts Folder has disappeared. How do I restore it? Using Outlook 2
E How to restore BCM Database after upgrade from Vista to Win7? BCM (Business Contact Manager) 1
D Can not restore database in business contact manager BCM (Business Contact Manager) 1
R Business Contact Manager - MDF and LDF file restore in Windows 7 BCM (Business Contact Manager) 3
S Restore a Meeting (accidentally deleted in my calendar) Using Outlook 3
F Possible to restore/reinstall "special" buttons on custom form? Outlook VBA and Custom Forms 1
M Backup and restore E2K7 with Server2K8 Exchange Server Administration 4
A how to access BCM database after system restore BCM (Business Contact Manager) 6
S Restore Deleted Folders and Emails in .pst Using Outlook 6
V Re: How can I restore a deleted distribution list to my contacts? Using Outlook 5
P default font when sending email from browser Using Outlook 1
A force outlook to default to MY calendar Using Outlook 3
e_a_g_l_e_p_i Outlook 2010 How to set default email address for website links Using Outlook 3
V Accepted meetings do not get the default reminder Using Outlook 0
Fozzie Bear Accepted Zoom Invites deleting without going into Default Calendar - Office 2016 Mac Using Outlook 3
O How come default profile changed? Using Outlook 2
