Advanced Search Question
David_H
Edit: found the answer here:
http://www.outlook-tips.net/tips/search-email-domain/
I frequently need to do searches on email sent to people at a specific company. For instance, let's suppose I want to search for the following:
- All emails sent to anyone with @microsoft.com as part of the email address.
- Do NOT want results for emails with Microsoft in the subject line, text body or anywhere else for that matter.
How would I enter this search?
Thank You
P Open Advanced Search Dialog Outlook VBA and Custom Forms 1
A Outlook Advanced Search Problems...returns with an Error: Argument Outlook VBA and Custom Forms 1
T Outlook 2007 Indexing Options and Advanced Search options disabled Using Outlook 5
H "Advanced find: column for full folder path? Using Outlook 1
Andrew Hawkins "Advanced Find" Using Outlook 1
P Outlook Advanced Find Using Outlook 0
S Advanced Find text field limits Using Outlook 2
C O2010: Using Advanced Find to locate exact queries Using Outlook 3
N Outlook 2010 crippled Advanced Find, now what? Using Outlook 3
H Outlook 2010 Advanced Find - Menu items missing Using Outlook 1
D Outlook 2010 - Advanced Find - No Status Bar = No Item Count Using Outlook 2
J How to filter by address fragment (e.g. "@domain.com") with advanced find? Using Outlook 2
N WINDOWNS LIVE SETTINGS / ADVANCED / REPLY E-MAIL (does not reply to email selected) Using Outlook 3
J Advanced outlook trick: help needed! Outlook VBA and Custom Forms 3
S Programmatically bring up Advanced Find for contacts? Outlook VBA and Custom Forms 1
L New Location for the Search Bar Using Outlook 6
King Mustard Sort search groups by amount of items? Using Outlook 1
T Search for incoming e-mails for a specified time range Using Outlook 1
R Search/Jump to a folder by typing its name Outlook VBA and Custom Forms 1
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
W Search Incomplete Outlook 2016 Using Outlook 5
R outlook address book search broken Using Outlook 2
R What's supposed to appear when just clicking into the search field? Using Outlook 7
