Outlook 2013 - Exchange 2007 manage distribution group
Jeroen Bonenberg
Outlook 2013 64 bit
Hi all,,
I have a question, which is still unanswered after a lot of Googling. I haver a customer, who's running Exchange Server 2007 on an SBS2008. Most of the users are working on an RDP server, the customer is running two of them. Both servers are Windows Server 2008 R2, one is installed with Office 2007 and the other one is installed with Office 2013.
I delegated manager rights to a user for a Universal Distribution Group, I did this through the Exchange Management Shell. In Outlook 2013 I'm still getting the error that the user doesn't have sufficient rights when he wants to change the members of the distribution group. But when the user logs in on the terminal server where Office 2007 is installed, the user is able to change the members of the distribution group with no errors at all.
Anyone having an idea what the problem could be?
Thanks in advance for any reaction.
Kind regards,
Jeroen Bonenberg
It may be a limitation of Outlook 2013/Exchange 2007 combination - in how permissions are handled in the client. Outlook 2013 only uses web services, not the Exchange addin. Exchange 2007 started the move towards web services but it's been while since I used it and don't recall how the permissions were handled, so i could be wrong.
I've seen permissions issues if the changes hadn't propagated to the client yet - it worked in online mode, not in cached mode. But with with RDP, you should be using online mode anyway.
L what is safe size for pst of Outlook 2013 via Office 365 exchange? Using Outlook 1
S Exchange server 2013 / Outlook 2013 Exchange Server Administration 3
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
Jon Bakrley Outlook 2013 and Exchange 2007, Out of the office error message Using Outlook 8
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
A Unable to send with attachments in Outlook 2013 (Exchange ActiveSync) Using Outlook 2
S Is Free/Busy supposed to work in Outlook 2013 not connected to Exchange? Using Outlook 14
J Outlook 2013 Change color of text in data fields of contacts in Outlook 2013? Using Outlook 9
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
M OUTLOOK 2013 CONTACT PROPERTIES Using Outlook 0
M Outlook 2013 Using Outlook 1
J Outlook 2013 hanging for unknown reason Using Outlook 1
