Sorting messages by read/unread status
murgatroyd
Outlook 2019 64-bit
I am using Outlook 2010 on a server running Windows Server 2008 R2. I want to sort the inbox and other folders first by read/unread status, then by received date.
1. I can sort by received date by clicking on the Received column heading, or by setting "Sort items by = Received" in the View settings, but this did not work with the Icon column. Is there a way to sort by read/unread status by using the Icon column?
2. I heard that the "Filter E-Mail" function and the Search > "Refine" function both provide an "Unread" option, but the "Filter E-Mail" icon and all of the "Refine" options are disabled (greyed out). How can I enable them?
I'm not sure why the filters are disabled - is windows search enabled? It might be something unique to windows server.
The read/unread state is not covered by icon - it sorts mail, meeting requests, receipts, replied to etc. You can add the Read field but it's basically useless as you can't sort or group by it (as you've discovered)
Filters (including Search Folders) can filter by read field. Or create custom views that shows only read or unread items. On View tab > View Settings, click Filter to set up an unread filer. Save it as a new view under Change View. Repeat to set up a Read filtered view.
murgatroyd
Outlook 2019 64-bit
Thanks for your reply.
1. I see that a "Read" column can be added from the Field Chooser to a folder view, but Outlook cannot sort by this column.
2. In Outlook on my PC, I can click on Filter E-mail > Unread, or Search > Unread, both of which set the search parameter to "read:no" and thereby display only unread messages in any view.
However, in Outlook on the server, the Filter Email button and all of the options in the Refine group on the Search tab are disabled (greyed out), and if I type "read:no: into the search box, no results are displayed. It appears that in order to use these advanced filter and search functions, Windows Search must be installed on the server, although Outlook can perform a basic text search without this.
However, I see that View Settings > Filter > More Choices > "Only items that are = unread" will display unread messages even without installing Windows Search.
Correct, Outlook can't do basic searches without windows search, but it needs it for instant search. The filters, which includes the View Settings, Search folders, Conditional formatting, doesn't use instant search, so yes, you can filter for items that are unread.
murgatroyd
Outlook 2019 64-bit
Thanks for your further reply.
I see that Outlook can search for text, and can filter read/unread messages via View Settings and Search Folders, without having Windows Search installed.
However, if I have numerous folders and want to view individual ones separately, sometimes showing all messages and sometimes showing only unread messages, then I need either to set up multiple Search Folders, or to have Windows Search installed and use Find > Filter E-Mail > Unread, or Search > Refine > Unread, to filter any folder instantly - is that correct?
I'd create a views, called Unread with filter set to show Unread messages. When you want to see unread items only, switch the view. Switch to the default view when you want to see all. If the view is create for all folders, you can use it on any folder.
murgatroyd
Outlook 2019 64-bit
I have created two views: "Unread" , with a filter to show unread message only, and "All", with no filter.
1. Is there a way to put the buttons for these two views on the Home tab of the ribbon for quick access?
2. I see that after selecting a view, I can click on View > Change View > "Apply current view to other mail folders" to apply it to all folders. However, is there a way to set up a view so that when I click on its button, the view is automatically applied to all (or specified) folders ?
No and No. Sorry. You can put Change views on the QAT so it's easier to access but would need to apply the views to all folders if that is what you want. Have you considered using an Unread search folder and grouping the messages by the In Folder field?
murgatroyd
Outlook 2019 64-bit
I see that I can use a Search folder to list multiple folders grouped by folder; however, each folder contains numerous messages, and I want to use each folder separately.
I have added the Change views gallery to the Quick access toolbar and will select the required view for each folder as needed.
P Is there any way of sorting the task list in CALENDAR view? Using Outlook 4
D Question re: Grouping by Due Date vs. Sorting by Due Date Using Outlook 1
J Outlook 2013 Sorting and grouping on 2 date fields Using Outlook 1
M Sorting "sent emails" is not logical. Is there a better way. Using Outlook 4
D Macro for sorting email according to sender and subject Using Outlook 0
S Sorting by combined categories in Outlook Using Outlook 1
M 2010: sorting by ORIGINAL send date Using Outlook 1
R Sorting and crossing over project tasks in project window (BCM 2010) BCM (Business Contact Manager) 1
B Sorting suggested times in room finder Using Outlook 1
P Sorting Task List so tasks with no due date end up at the bottom Using Outlook 4
A Sorting of existing contact in Outlook 2003 just will not sort Using Outlook 2
Q Sorting tasks by calculated field - automatically update task-fiel Outlook VBA and Custom Forms 9
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
S Conditional Formatting for messages in a Conversation thread Using Outlook 1
GregS Outlook 2016 Sent Items vs Sent Messages Using Outlook 2
snissen Printing foreign language messages Using Outlook 1
S Receiving duplicate messages from RSS feeds Using Outlook 3
R Can't send messages to groups in Outlook Using Outlook 2
icacream outlook keeps neither SENT or FORWARDED messages... they vanish ! Using Outlook 4
W Receiving messages in offline mode Outlook VBA and Custom Forms 1
RangerRick Text Extraction from forwarded messages external Exchange Server Administration 1
L How to use different fonts for outgoing messages for different email accounts Using Outlook 0
T SMTP messages stuck in Outbox Using Outlook 0
Mark White VBA to deal with Recalled messages Outlook VBA and Custom Forms 7
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
Liza Creating a rule in outlook to filter messages Using Outlook 0
S Automatically selecting folders and deleting messages in Outlook VBA Outlook VBA and Custom Forms 7
Diane Poremsky Save Messages and Attachments to a New Folder New Slipstick.com Articles 0
P AOL messages Outlook VBA and Custom Forms 0
Diane Poremsky Create a custom field for Outlook messages New Slipstick.com Articles 0
I Identify Number of email messages opened Outlook VBA and Custom Forms 7
Diane Poremsky Monitor secondary mailbox folder for new messages New Slipstick.com Articles 0
