outlook 2010 delegation problem
junqi89
Outlook 2007
Dear all,
one of my user encounter an outlook delegation error. it say that the delegate were not save correctly. cannot modify access control list.
The troubleshoot step i did. User test on another machine which is running on outlook 2007 no issue with that. But when change to outlook 2010 the delegation error take places. i re-create the profile but still same issue. i have also added this dword IgnoreSOBError and modify to value 1 HKEY_CURRENT_USER\Software\Policies\Microsoft\Office\x.0\Outlook\Preferences
Re-install and un-install outlook 2010
unfortunately, i still encounter the same problem. But when i try to delegate on my site using outlook client version 2010. i have no problem at all.
can anyone advise me on this?
i kindly appreciate your kindness help.
thank you.
junqi89
Outlook 2007
What version of Exchange server are you using?
I assumed you used the correct version # in the key: \x.0\
you mean outlook client ? if you are talking about outlook client i am using version 2010. if you talking about server exchange the version is 2007.
e_a_g_l_e_p_i Gmail in Outlook 2010 preview issue Using Outlook 0
