Default calendar and IMAP
Dexter22
Outlook 2007
I have been trying to find a solution to this and believe it it out there but cannot seem to locate the answer. I have both a POP account and IMAP account (Google) in my Outlook. IMAP is my business use and POP is my personal use. Each has its own calendar. I am using gsync to synchronize my IMAP calendar, tasks and contacts.
I am experiencing the following problems:
1) When I receive an appointment request in outlook for outlook (sent to my work email), it is creating an entry BOTH in my IMAP calendar and my personal POP calendar. I just want it to go to the calendar of my IMAP account.
2) When I create an appointment in my IMAP/work calendar, and invite people, I get a message that responses will NOT be tallied because it is not in my default calendar. Hence, I cannot keep track of the responses.
I tried to set the IMAP calendar to be my default but Outlook will only allow my personal POP account calendar to the default.
I have found multiple answers that say that IMAP cannot be the default. Therefore, I am asking the forum the following:
1) Can I set the IMPA to be my default calendar?
2) If I cannot, how do other people use Outlook for both a personal and business calendar without invitations being created in both calendars?
Help?
Correct, imap can't be default when you use Outlook 2010 or older. Are you using the Google sync utility (available with the google apps account)? I don't think there is any good way to avoid duplicates when a utility is syncing two calendars, unless the utility is moving the appointments, not copying them.
Most people don't use google for business accounts - if they have an exchange account, it doesn't create copies of the appointment. If they use pop3 or other imap accounts, the appointments don't sync with anything.
C Delete Subject-Add Organizer to all Reservations in Default Calendar. Using Outlook 0
B Outlook 2016: Can't delete default calendar but I don't use it Using Outlook 7
B Calendar shows too much info by default Using Outlook 0
M Default Calendar Using Outlook 0
J Installed Outlook but Default Calendar is Blank Using Outlook 3
S Default Calendar Reply Addresses Using Outlook 2
A set onedrive calendar as default in Outlook Using Outlook.com accounts in Outlook 4
K Outlook 2013 Multi Accounts set Default different calendar Sender Using Outlook 2
G Outlook 2013: Cannot Edit default Holiday Calendar Using Outlook 2
S Outlook 2010 trying to default Data file to outlook.com calendar Using Outlook 6
M How to set default calendar & contacts Using Outlook 0
J How to change my default calendar...? Using Outlook 1
B Setting Default calendar - using exchange mailbox and a .pst Using Outlook 2
O Exchange + pst: Can I change the default Outlook calendar/tasks/account? Exchange Server Administration 2
Horsepower Default calendar to receive email appointments Using Outlook 5
G how to change default calendar view to show this week and future weeks? Using Outlook 1
M How to set exchange calendar as default when combining with Internet calendar Using Outlook 2
J Default Category foo Calendar Appointments Using Outlook 1
R OL 2010 default calendar view Using Outlook 6
L Outlook 2010 Default Calendar Using Outlook 2
E Pull Data From Non-Default Calendar Outlook VBA and Custom Forms 2
O How come default profile changed? Using Outlook 2
T Outlook changes default account Using Outlook 1
V VBA when replying + Default Account Using Outlook 2
P Outlook.com account overrules default account Using Outlook.com accounts in Outlook 8
P Outlook 2016 Not Default Client Using Outlook 5
D Add all meeting rooms to the meeting request by default Outlook VBA and Custom Forms 0
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 5
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 0
N How to delete default folder "Contacts" (olFolderContacts) in a .pst file Using Outlook 8
D Default Send Account that Works? Using Outlook 0
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
