problems downloading POP3 emails to Outlook 2003
john mylonas
hi helpful people,
i have a few emails backed up on my pop3 account but they have stopped coming through to outlook.
usually they dont come through unless i click 'send/receive', but now, they are not coming through at all.
Can anyone assist me? I havent commenced any new anti-virus software or played with any of the settings.
Would appreciate any assistance. Thanks.
latitudeit
Outlook 2013 64 bit
Can you connect to any other pop server? My first step would use telnet from command line to try and connect to the pop3 server to see if you can establish a connection in the first place or if something is blocking it. To check pop using telnet you would run a command like telnet pop.myserver.com 110 - if the server answers at least you know you can connect to it! If you get no answer check firewall and antivirus settings.
C problems Using Outlook 1
