2013: Task Views keep disappearing
piusg
Outlook 2013 32 bit
Hi all. I've done my due-diligence and searched for this issue in the existing threads, and don't see one that closely matches what I'm looking for... so, here goes.
I like to create several custom views in Outlook Tasks. When I upgraded to Outlook 2013 from 2010, all my custom views have disappeared. Gone. Can't find them anywhere. It took me days to set these views up to my liking and now they're completely gone.
Even worse: When I try to recreate them, I get an error message saying that a view by that name already exists! *headdesk* *headdesk* *headdesk*
So where on Earth did my views disappear to? How do I retrieve them? And how do I keep this from happening in future?
Thanks in advance,
Gregory
Dang Enter. :)
If you don't see them you could restart Outlook with the /cleanviews switch - this will wipe them out completely and you can start over. However, unless the Exchange ost file is huge, I'd delete it and let outlook rebuild it. This could bring the views back so you won't need to recreate them.
piusg
Outlook 2013 32 bit
I actually did recreate the views, and they seemed to stick around this time. I wonder if some enterprising soul has written some VBscript to export and import views in the OST, as there seems to be no way to do this naively, and they seem fairly fragile...
Thanks again, Diane. You really know your Outlook. I'm very glad I joined these forums.
I'm not aware of anyway to save or backup views, short of copying them to a folder for 'this folder only', then repeating the process to restore them, for 'all folders'. A macro can't export them (Outlook can't export them either.)
santheocles Issue in Outlook 2013 - cannot reschedule single task Using Outlook 0
C outlook 2013 task reminders vs. outlook.com task reminders Using Outlook.com accounts in Outlook 8
S Outlook 2013 To Do Task does not minimize. Using Outlook 0
F Combine Outlook Task Folders into one View (Outlook 2013) Using Outlook 3
K Starting Outlook 2013 x64 minimized in Win 8 with or without Task manager Using Outlook 5
T Office 2013 no longer updating automatically Using Outlook 2
David Michaels VB coding works in OL 2010, but not in OL 2013 Outlook VBA and Custom Forms 4
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
M OUTLOOK 2013 CONTACT PROPERTIES Using Outlook 0
M Outlook 2013 Using Outlook 1
