2013: Place custom view on the ribbon
piusg
Outlook 2013 32 bit
Greetings, all.
I've never been able to figure this out; maybe someone in the community can give me a hand.
I'd like to be able to place a custom view that I've created on the ribbon. Is that possible? I can't seem to find an obvious way to do that in the ribbon customization.
Thanks in advance,
Gregory
piusg
Outlook 2013 32 bit
Thank you Diane. I appreciate it. I notice that you don't often get a lot of "thank yous" on your replies, so I'd like to say thanks and that I appreciate your devotion to these forums. I may not get to implementing this straightaway, but when I do, I'll post the results.
Thanks again!
Gregory
T Office 2013 no longer updating automatically Using Outlook 2
David Michaels VB coding works in OL 2010, but not in OL 2013 Outlook VBA and Custom Forms 4
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
M OUTLOOK 2013 CONTACT PROPERTIES Using Outlook 0
M Outlook 2013 Using Outlook 1
J Outlook 2013 hanging for unknown reason Using Outlook 1
K Rebuilding Outlook 2013 from Outlook.com after OS rebuild Using Outlook.com accounts in Outlook 2
Diane Poremsky Block Macros in Office 2013/2016 New Slipstick.com Articles 0
